If you're looking to have anything done be sure to give us a shout!
-Russ
thanks. What is the price for the jobs?? I didn't expect 3 different programs so what kind of gains are from each/ benefit from each? I have a BTR stage 4 cam and stock bottom end if it matters. Thanks!
99blkfrc99,
Do you plan to run a power adder? Gains vary dependent on setup, fuel, tune, header choice, etc. Have you already installed your setup and ran it at all?
-Russ
yup, it's installed and running. Don't plan on a power adder, would like to stay NA. Just wondering if there is more on the table to be had. Or pick up in the mid range. Thanks
