Transmission leak
Old Aug 1, 2017 | 05:39 PM
Leggs111's Avatar
Leggs111
1st Gear
Default Transmission leak
I own a 1999 C5 corvette and testing station have picked up a leak of transmission fluid covering spring hanger rubbers. Anyone else have this problem and what is the possible fix please. Many thanks.
Old Aug 1, 2017 | 09:04 PM
PDQC5's Avatar
PDQC5
My 98 was leaking from the trans rear seal
Old Aug 2, 2017 | 12:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Is it really TRANSMISSION FLUID or is it DIFFERENTIAL 75/90 gear lube FLUID???
Trans fluid in our C5 MN6/MN12 or A4 is ATF Fluid..
What is the actual leak fluid????? ATF or 75/90 Gear lube????
If its stinky 75/90 Gear lube, then its a differential leak/seep
Please check and report back. Give it a taste and see...
To Transmission leak
