NEED HELP. Car not starting.
Old Aug 3, 2017 | 07:23 PM
Logiieee's Avatar
Logiieee
Default NEED HELP. Car not starting.
I have a 98 corvette and I am having trouble starting my car. The car starts for and instantly dies while making a screeching sound. I can smell some metal burning/rubbing together. I cannot start car now and need to know what the issue might be.
Old Aug 3, 2017 | 08:51 PM
Spaceme1117's Avatar
Spaceme1117
You need to give more detail about both the problem and your car. Is it a manual or auto? Has there been any work done to it lately? Can you see anything abnormal on or near the engine? Any codes registered?
Old Aug 3, 2017 | 10:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Remove the serpentine belt and AC Belt and see if that changes anything. That way, you eliminate a whole bunch of driven components.
Put the trans in N and leave the clutch out. Depress the clutch. Shift into gear and depress the clutch. That will tell us if the Clutch/TT is part of the issue..
Bill
Old Aug 4, 2017 | 12:06 AM
Logiieee's Avatar
Logiieee
It is an automatic, I recently got a new rpm lvl 6 trans, new torque converter, and c6 zo6 stub axles. I do not see anything abnormal. There are no codes being thrown. Right when the car starts, it immediately dies and makes a grinding noise in the engine bay somewhere.
To NEED HELP. Car not starting.
