Next possible mods?
Good luck and let us know what you end up with.
That being said, that's the FIRST part of the drivetrain that will require your attention. Depending on how you drive, your future goals and mods, etc, will determine if other parts need some help. The rear differential might need to be replaced, possibly the axles, torque tube might need some help and so on. Also better shocks (coilovers maybe?) might be wanted or desired.
It seems that about 450-500rwhp is about max that the stock stuff can handle and I'd say the A4 is the weakest link in the bunch. Therefore, depending on where you want to end up will determine what needs to be done. As for me, I'm absolutely crazy and have a supercharged LS3 in my 98 that is approaching 700rwhp on 7.5lbs of boost. Virtually everything in my drivetrain has been changed out. Trans rated at 750rwhp. Rear end from ECS rated at 1000rwhp. I still have my original torque tube but it does have new guidos (look that one up).
(It's the rubber bushings). I have dual adjustable coilovers. Lots of $$, lots of time but this is what I enjoy and wouldn't change a thing.... You just need to think about where you want to go with yours... Keep us posted.
Don't waste your money on N/A stuff
