ASP Pulley installed...results inside!
Old Oct 5, 2002 | 11:57 AM
Black Magic's Avatar
Black Magic
Default Re: ASP Pulley installed...results inside! (RCswish)
They make both under drive and overdrive alternator pullies for our cars. In fact they are only $15 or so. Takes 10 minutes to install. Check Thunder Racing... :)
Old Oct 5, 2002 | 12:49 PM
Barely Legal's Avatar
Barely Legal
Default Re: ASP Pulley installed...results inside! (Black Magic)
Where are the results?
Old Oct 6, 2002 | 12:12 AM
RCswish's Avatar
RCswish
Default Re: ASP Pulley installed...results inside! (Barely Legal)
Well do to fact that I'm running a 230 cam with no tuning, my injectors maxed out, and the A/F ratio was so rich it was off the chart, and to top it off I am throwing 4 codes with a broken air temp sensor...my dyno results are inconclusive. I need to fix the sensor and get the car tuned...then back on the dyno. With my car spitting fuel out of the tail pipes (AF is waaaay off)...I still hit 405rwhp at 5800 rpms. With tuning, fixed sensor, and rev limiter up to 6700 I expect to hit 435+ rwhp easily. Sorry I couldn't get the numbers you guys wanted to see.
I have to thank Dave from Black Magic again for coming down to the dyno day to bolt on my intake manifold...you didn't have to drive all that way...Thanks. :cheers: I think I will pick up one of those alternator pullies just in case I need to bump some urban rap jams at high decibles while driving 192 mph while charging my cel phone. :jester
