Broken axle stub??
Old Aug 7, 2017 | 06:37 PM
juggernautZ06's Avatar
juggernautZ06
Default Broken axle stub??
So I think I broke my axle stub. Right side engages. Left side just spins freely. When I spin the right side it's hard to turn. I can hear it in the transmission when I Rock the right wheel back and forth. Any ideas?? Drag strip launch btw.
Old Aug 7, 2017 | 06:57 PM
Smoken1's Avatar
Smoken1
Time for a diff rebuild
Old Aug 8, 2017 | 06:22 PM
juggernautZ06
looks that way anyone ever use rpm or Zip corvette?
Old Aug 8, 2017 | 06:57 PM
Smoken1's Avatar
Smoken1
Yes, I have the RPM stage 3 diff
Old Aug 8, 2017 | 08:33 PM
StingrayRebel's Avatar
StingrayRebel
rpm or Rick at rkt56
Old Aug 10, 2017 | 07:24 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
If you're mechanically inclined, do it yourself.
It's not difficult. But, it is time consuming because you have to drop the trans/cradle/diff. But, you have to do that anyway if you're gonna replace it.
Old Aug 10, 2017 | 08:07 PM
juggernautZ06
Talked to RPM gonna go with a Stage 3 Differential. Gonna start on it next week. Gonna take my time and be in no hurry.
Old Aug 13, 2017 | 09:02 PM
juggernautZ06
Broke the left axle stub. It's confirmed. Anyone know how to get the broken piece out of the axle
Old Aug 13, 2017 | 09:35 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Yep. BTDT...
Drill and tap. You can use a slide hammer to get it out.
Good luck!!
Old Aug 15, 2017 | 10:21 AM
huesmann's Avatar
huesmann
Or weld a bolt or something you can yank on onto the broken surface?
Old Aug 15, 2017 | 10:41 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hmmmmm.. Just to repair the output shafts and do a little hardening, you can do it your self!! I did this C6 ZO6 improvement to mine and its been fantastic. ZERO ISSUES and it was a straight forward repair.
Check out the links:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Old Aug 15, 2017 | 10:44 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you launched, did you experience any wheel hop or drivetrain shake??
Some things that you can do to make the differential and drivetrain a little more stable and resist shake and hop, is to install better shocks (C6 ZO6) and a better differential mount.
To Broken axle stub??
