ARH 1-3/4" Install Problems
My car is on jack stands, and I have about 19" between the oil pan and the ground. I have removed the starter. I have removed the passenger side valve cover. I have removed the engine mount nuts, and jacked the engine up to the point where wiring harnesses at the back of the manifold are just touching the firewall.
If I go through the top, the runner for the sixth cylinder contacts the air-conditioning hardline and/or the runner for the eighth cylinder, near the flange, gets caught on the hard line. The collector almost gets to where it needs to be, but the header cannot be rotated into position because of interference with the cylinder head, air conditioning hard lines, and the frame rail.
If I go through the bottom, I run into interference between the header flange and the cylinder head, and I can't get the flange near the eighth cylinder through the space between the bell housing and the transmission tunnel.
I'm at my wit's end... Supposedly these were supposed to go in easily. Can anyone help? Thank you
I installed the 1 3/4" ARH headers on my 2001 (manual trans) last November. It was a lot of work, but I learned a lot.
I don't think removing the valve cover is going to be of any help.
Once you figure out the angle of attack getting the passenger side is about as easy as can be. Install them from the BOTTOM.
There are no short cuts, so just take the time to do it like ARH shows on their instructions (they really do over-simplify those instructions, though).
Did you remove all spark plugs and wires?
Did you disconnect the battery cables and remove the battery, and the battery surround?.
Make sure there is an extremely clear path with NO WIRES hanging down - no starter wires, no O2 sensor wires, etc. It is worth the time to make sure the wires are tied back with string or wire.
I seem to remember that if you tilt the outlet end of the header down the front of the header flange will slide up and clear the block, etc. You may need to twist the outlet end in towards the center line of the car. As the flange gets higher you want to bring it horizontal and parallel to the cylinder head.
I used a really stout piece of bungee cord (about 4 foot long) as a helper. Much better than a piece of rope because of the stretch factor. When I got the header positioned at the bottom I could go topside and tie-off the cord to a hood-stop or other point and take time to analyze the situation.
The guys at ARH were not particularly helpful, but they assured me that it was not a complicated thing. I sort of liken it to the way a Kindergarten teacher would say, "You can do this Bobby. I know you can!"
Hope that helps. And you will like the final result.
My ARH instructions don't have any pictures, but I read them, and thought I was following them.
All of the plugs and plug wires have been removed.
Your description of "vertically" feeding the header in from the bottom, and then twisting its orientation as the header is "leveled" is pretty much what I've been trying to do. Interference from the frame rail, bat wing, and bell housing has thwarted me...
I'll give it another shot, though. Thanks for responding. Anyone else...?
I think you need to BEGIN entering the header from further back than you might normally think. IOW - not directly under the cylinder head area, but rather about the same distance back as the firewall.
That's where I run into trouble: as I rotate the header so that it's closer to getting level (collector pointed more toward the back of the car), and try to rotate it around the bat wing, the #6 runner seems to get caught on it. There isn't anymore space between the primaries and the frame, and then the flange gets caught up between the bell housing and the transmission tunnel.
I re-read the instructions after you posted. They say, "[n]ote: 304 S/S tubing can shift slightly during the assembly process. When this happens the install may require loosening of motor mount nuts and a quick pry of the engine opposite of the side being installed. Though this rarely occurs it does happen."
When I jacked up the engine, I raised the passenger side while attempting the passenger side header. It sounds like the instructions actually called for jacking the driver's side of the engine while working on the passenger side. I'll give it a shot, but I'm beginning to suspect either my car or the header is way out of spec.
Thanks again.
So I probably told you wrong about how far back to start.
Hope that helps some more.
The key for me was to put in from bottom, looks like plenty of room but like you couldn't get the last mounting hole to pass batwind. Then I rotated the bottom of header so the last bolt hole on header flange was on the same plane as the frame rail at corner of batwing. It is real close but the flange bolt hole will pass between the corner of batwing and frame.
It went in so easy once I lined it up that I removed the header, put starter back on and reinstalled it in less than a minute.
Extremely easy once I figured out the path it needed to go. Try again and focus on the small gap between the frame and very tip of the pan.
Anyone else have any tips?
Does your A/C still work okay?
Thanks!
In the interests of helping someone down the road, I actually called ARH a couple of days ago, and they said that if the headers are fighting you like mine, it helps to have another person slightly shift the engine with a pry bar while you work the headers in, and just keep working around whatever they might be catching on. ARH said thats how the guys who install them at Carlisle do it.
Anyway, thanks again. It's much appreciated.
I also was going to take photos of mine since I suspect my car is on the tight side - none of the suggested angles of attack, short of lifting the engine a bit have come close to allowing the headers to fit. I suspect bending the hard line will get them in. Stay tuned.
Thanks again.
