Codes on No comm
Old Aug 14, 2017 | 02:12 AM
kg54trains's Avatar
kg54trains
Default Codes on No comm
98 auto coupe.. Have A6-scm(no comm) and BO-RFA(no comm) .. Had the horn bladder repaired/replace and also discovered horns were shot but replaced with PIAA with same electrical drawn so just a straight replacement using the same leads.. Prior to the mechanic visit for this my battery was drawn down result of a interior light being on.. AAA jumped the battery and one turn of of the key and fired up.. Battery gage shows a 14 when started.. Mechanic told me that they checked fuses to discover the oem horns died.. Since then I lost the Key FOB use and FOB Training is no help cause it will not enter the training mode.. Tire sensor are at no numberical number front and back.. These codes are a showing up RFA-no comm and A6SCM- no comm.. I am at a need of information regarding these codes.. Any help would be appreciated.. Live in SE PA and do not want to have a dealer run it down.. Have had problems with their work on my Vette
