Does your engine “rattle” when you turn it off?
Old Oct 4, 2002 | 12:09 PM
JMon's Avatar
JMon
Cruise-In III Veteran
Default Does your engine “rattle” when you turn it off?
Every once in a while maybe once a week, my engine rattles when I turn it off. Maybe it is dieseling or something. Only got 30,000 miles on it though. Maybe it’s not that at all. Any idea? Anyone else have this happen?
Old Oct 4, 2002 | 12:48 PM
lost's Avatar
lost
Default Re: Does your engine “rattle” when you turn it off? (JMon)
Assuming you are running premium gas, I would guess that bits of carbon are creating hot spots in the combustion chamber. I have found in the past that adding some fuel injector cleaner and a blast thru the gears does a pretty good job. Of course I blast thru the gears every chance I get. When I changed heads on my Mustang with 60k on the motor, my combustion chambers were exceptionally clean, so I know it works...
Old Oct 4, 2002 | 12:49 PM
THENAKEDi's Avatar
THENAKEDi
Try keeping your clutch engaged when you shut down. If the noise is gone, you have the same situation as the rest of us. Normal, so they say. Good luck!
Old Oct 4, 2002 | 01:04 PM
flynbludream's Avatar
flynbludream
Default Re: Does your engine “rattle” when you turn it off? (THENAKEDi)
It's your clutch.
O-Ace's Avatar
O-Ace
I'd say its normal.
Old Oct 4, 2002 | 11:41 PM
TooManyIDs's Avatar
TooManyIDs
Old Oct 5, 2002 | 12:32 AM
6500RPM's Avatar
6500RPM
clutch (normal)
Old Oct 5, 2002 | 10:25 AM
ShelbyC5's Avatar
ShelbyC5
I have an A4 and I think I've heard what your talking about. Very suble though. It has since dissapeared. I wouldn't worry about it unless it gets worse. Take your car for a good drive & open her up a few times. ;)
Old Oct 5, 2002 | 03:30 PM
Crushinator's Avatar
Crushinator
Default Re: Does your engine “rattle” when you turn it off? (ShelbyC5)
Every 6 speed Corvette I've ever been in does it without the clutch engaged. As mentioned, try leaving the clutch engaged and see if it still does it.
It's Normal.
Old Oct 6, 2002 | 03:02 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Does your engine “rattle” when you turn it off? (QuickSilver97)
It's never been a problem with mine.
Old Oct 6, 2002 | 12:00 PM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: Does your engine “rattle” when you turn it off? (FunDriver)
normal c5 sounds :yesnod:
thanks
Old Oct 6, 2002 | 07:40 PM
Pat97Vette's Avatar
Pat97Vette
I have 33k on my 97, and have heard it intermittently. I would assume that it's the clutch making this sound, also. I just live with it.
Old Oct 6, 2002 | 10:50 PM
fins4284's Avatar
fins4284
Default Re: Does your engine “rattle” when you turn it off? (TooManyIDs)
Old Oct 7, 2002 | 11:34 PM
dustyhuff's Avatar
dustyhuff
If your car is an M6 it will rattle when you shut the car off. If you shut the car off with the clucth in it won't rattle. Chevy doesn't have a fix for it either, I've tried.. :boxing
[Modified by dustyhuff, 3:34 AM 10/8/2002]
[Modified by dustyhuff, 3:35 AM 10/8/2002]
Old Oct 9, 2002 | 01:13 AM
BigBlue's Avatar
BigBlue
Default Re: Does your engine “rattle” when you turn it off? (dustyhuff)
You know? For as much money as we pay for these cars, they should last a life time. Without any rattles or what have you. They should also be beating Cobras. Which cost half as much.
Oh yeah. I occasionally hear my dad's rattle. But I usually have the Bose system turned up so loud that i can't hear a blasted thing. :D
To Does your engine “rattle” when you turn it off?
