98 corvette auto car won't start
10pcm p1518
28 tcs c1278
40 bc no comm
60ipc u1160
1176
1040
Head no comm
HELLLLPPPPPPP!
I think you are jumping the gun and doing something that doesn't need to be done. You said that you LOOKED at the fuses BUT,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, Did you actually CHECK the voltage on EACH BCM Fuse??????????????????????????????
On top of each FUSE are two test slots. Turn the ignition switch to ON and use a DC Volt meter and read both fuse test slots on each fuse to CHASSIS GROUND. You should see FULL BATTERY VOLTAGE on each fuse!
If you don't have actual power on ALL the BCM Fuses, you could install 100 BCMs and it is NOT going to WORK.
That BCM did NOT look corroded from getting wet to me.
If you need a good used BCM, contact VETTE NUTS (Marc) and he will most likely have the one that you need (If you actually need one!)
Bill
