Gauge Cluster
Old Aug 21, 2017 | 01:38 AM
LS1 REDBIRD's Avatar
LS1 REDBIRD
Default Gauge Cluster
How can I bench test the cluster??
Replacing a turn signal light and will also be changing the gauge lights to LEDs. I changed the door control lights and I had to flip a couple of LEDs. Assuming it was a polarity issue. Though I seen someone use a 9volt battery to test the cluster?
Old Aug 21, 2017 | 05:36 AM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
I use a portable car jump starter
http://www.ebay.com/itm/Battery-Jump...qD0H9Bwtyna7kQ
Or there's this
http://www.ebay.com/itm/12V-Car-Port....c100005.m1851
Old Aug 22, 2017 | 01:07 AM
LS1 REDBIRD
Which wiring pins need to be connected?
Old Aug 22, 2017 | 02:44 AM
sirdano's Avatar
sirdano
I thought gauge light used black light?
Old Aug 22, 2017 | 02:46 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You would be CORRECT!
All of the speedo, tach gauges faces, numbers and gage hands are lighted by the two small black light tubes.
All of the warnings and indications on the face are back lighted by bulbs.
Bill
To Gauge Cluster
