Question.............
Old Aug 24, 2017 | 10:31 AM
jbclutch's Avatar
jbclutch
St. Jude Donor '09-'12
Default Question.............
Have a 99, LS1, VETTE....Is there a way to up the voltage to the spark plugs?
Old Aug 24, 2017 | 12:50 PM
grantv's Avatar
grantv
Why? What do you want to achieve?
AFAIK the ignition system is not a bottleneck for moderate builds by any means.
Old Aug 24, 2017 | 12:58 PM
foggy's Avatar
foggy
Stock GM coil packs are NOT ford crap !!
Alot of people use them well into the 700+ HP range.
They are very good and very reliable
Old Aug 27, 2017 | 12:32 AM
CactusCat's Avatar
CactusCat
Short answer is yes, but unless you're running some mods, there's not much need for them. I'll post a link but remember all the stuff you read is being pitched by the company that's trying to sell these.
http://performancedistributors.com/p...-ls-sos-coils/
Read their PDF file
Old Aug 28, 2017 | 10:32 AM
jbclutch's Avatar
jbclutch
Default not stock
Read their PDF file
have mods..
Old Aug 28, 2017 | 12:59 PM
cv67's Avatar
cv67
St. Jude Donor '05
you still dont need it spend your money somewhere else ignore fancy marketing ads
dont mean to sound blunt but if there was an advantage to it GM woulda done it or be selling it out of their GMPP catalog
Old Aug 28, 2017 | 02:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LS1, LS6, LS2,,,, etc.. Have excellent ignition systems. The STOCK coils work well into the 700-800 HP range
There is ZERO magic HP if you purchase a $500.00 set of wires, $25 dollar each plugs and get Super Wham-O-Dyne $$$$ coils.
The LS2 coils are a little better than the C5 LS1/LS6 Coils in that they will take more dwell without overheating.
I would NOT worry about coils,, Unless you have some serious HP and or Forced Induction and you are experiencing issues with misfires under heavy acceleration full throttle loads, and the wires and plugs are not the issue.
SPARK PLUG WIRES. I have found the best bang for the buck (quality and performance ) is a set of GM Performance RED wires. Wires DO NOT add HP. You should look for quality construction, excellent materials and proper fit. Those wires do all that and only cost around $60.
If you have headers that burn up any wire that you install, them you have to spend the bucks and get the ceramic wires that resist extreme heat.
To Question.............
