Balancer bolt
Old Aug 24, 2017 | 09:47 PM
Kj814fun's Avatar
Kj814fun
Default Balancer bolt
Anybody got any good ideas on how to get out the original balancer bolt out? No success yet.
Old Aug 24, 2017 | 10:25 PM
DVUSz06's Avatar
DVUSz06
I used a socket, breaker bar, and 1/2 a fkoor jack handle, they are tight.
Old Aug 24, 2017 | 10:28 PM
tbrowne's Avatar
tbrowne
Generally, if you have a quality socket and a long breaker bar with a cheater pipe on it - it will come loose. You do need a method to hold the engine from turning while applying force to the breaker bar. The best way to hold the engine is to remove the starter and attach a flywheel holding tool into the flywheel. If you have a helper, the helper can wedge a large, flat blade, screw driver into the flywheel teeth and hold it that way. Both will work. There are other ways and I'm sure you'll get more comments on those. An impact wrench is not recommended because the hammering can damage the delicate crank bearings.
The tool in the picture is about $30.00 on ebay.
Old Aug 24, 2017 | 11:36 PM
StingrayRebel's Avatar
StingrayRebel
if the car is a manual you can put it in 4th gear, pull the ebrake tight, and chock the front side of the tires... that should keep it from moving enough and you can get a breaker bar on it from the top, a cheater bar on the breaker bar helps... just be careful so you don't slam the breaker bar into the car when it breaks free
Old Aug 25, 2017 | 12:05 AM
foggy's Avatar
foggy
IF you are replacing the balancer..
You can heat up the bolt with a propane torch..
You don't need to melt anything down, but the heat help to release
the factory threadlocker on the bolt. Then you can just hit it with an impact
gun.. Remember the OE bolt is a 1 time use only. Go with ARP when replacing
Old Aug 25, 2017 | 08:15 AM
Paul 75 L82's Avatar
Paul 75 L82
You need a strap wrench, best way to lock it up when you have to get to 240 lbs of torque to put the new bolt in.
Old Aug 25, 2017 | 09:38 AM
huesmann's Avatar
huesmann
Does the "put a breaker and cheater bar on it and bump the starter" method work on a Vette?
Old Aug 25, 2017 | 10:18 AM
Ludeaem's Avatar
Ludeaem
use a mini torch on bolt for 2-3 minutes. That combined with it being in 6th gear and a breaker bar did it for me. Pretty painless
Old Aug 25, 2017 | 11:23 AM
radar502's Avatar
radar502
These bolts can be a bear . I took a 7FT. yep 7FT. 3/4 breaker bar and a pipe wrench and two people on the 7 FT. bar . I tried in 1st gear was turning the motor over yep in 1st gear.. I tried all that BS people said on here well you just... No mine was a bitch .. 260 LB .. Pm me I tell you how I did it and held the motor from turning .. A pipe wrench old school .. You will need to phone a friend for sure not a one man job ..
Old Aug 26, 2017 | 04:25 PM
surenow's Avatar
surenow
Get on it with air hammmer and all you're made up of. Make sure it;s a six point socket.
Old Aug 26, 2017 | 07:33 PM
vettenuts's Avatar
vettenuts
I have removed several on stick cars. Emergency brake, rear wheels on the ground and a high gear (5th). I just used my 1/2" breaker bar and a good socket.
I would not attempt with bumping the starter. The starters on these cars are bolted to an aluminum casting and many have had the starters break off for other reasons, IMO using it to try and remove the crank bolt is asking for big problems.
To Balancer bolt
