02 z06
Old Aug 27, 2017 | 11:21 AM
FASTNUF!'s Avatar
FASTNUF!
Cruising
Default 02 z06
Replaced the drivers side front turn signal and now my headlights want go down. Checked both rt & lt motor fuses, both good. When removing the bulb the glass broke and I had to use a set of plyers to pull it out, so both the hot and cold wires of the bulb were touched at the same time, if this helps any?
