C5: replace lifters without removing heads?
Old Aug 28, 2017 | 04:50 PM
sunvet's Avatar
sunvet
Default C5: replace lifters without removing heads?
On 2000 C5 stock engine, is it possible to replace the hydraulic lifters without removing the heads? I thought I saw that there is a guide under the heads that must be taken out first.
I have a noisy lifter, but it wouldn't be worth it to me to replace it right now if I have to take the heads off.
Old Aug 28, 2017 | 08:22 PM
Carl Timonen's Avatar
Carl Timonen
Heads need to come off.
Old Aug 28, 2017 | 08:24 PM
sunvet's Avatar
sunvet
Thank you.
Old Aug 29, 2017 | 01:04 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
As you can see,,, When the HEAD goes on, the lifters are inaccessable.
Bill
Old Aug 29, 2017 | 01:53 AM
sunvet's Avatar
sunvet
Thanks for the pictures. Yeah, I could get to the lifters on the engine in my old mustang by just removing the windage tray.
Old Aug 29, 2017 | 08:13 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Is there any real advantage to having the lifter trays "captured" by the cylinder heads??
Old Aug 29, 2017 | 11:47 AM
corvet786c's Avatar
corvet786c
Yes they prevent the lifters from turning. The trays keep them stable.
Old Aug 29, 2017 | 05:10 PM
wcsinx's Avatar
wcsinx
Gen 1/2s you could get to them from the intake valley. Not so much with gen 3+ ... heads gotta come off
Old Aug 29, 2017 | 05:56 PM
leadfoot4's Avatar
leadfoot4
I know that the trays keep the lifters from turning, my question was why the designers chose to design the trays such that the heads need to come off, to remove the trays. The previous generation of SBCs had "dogbones" to hold the lifters in the proper orientation, and the sheet metal "spiders" to hold the dogbones in place. The entire deal was accessible, AND removable, from the valley.
With the current design, if you have something as simple as one lifter gone "wonky", you have to pull a cylinder head, to replace it. That's a significant amount of work, for what could be a simple problem.
Old Aug 29, 2017 | 09:55 PM
wcsinx's Avatar
wcsinx
Everything is a compromise is one form or another. I suspect it was designed that way for structural integrity. And if 100k miles later the heads have to come off to replace lifters well...
Old Aug 29, 2017 | 11:01 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
It would be interesting to hear from the design team why they made some decisions. I doubt replacing lifters was much of a consideration for GM as they are not considered a wear item, and being designed from day 1 as an aluminum block rigidity was likely a priority.
GM would have to open up the area towards the lifter valley in the block to possibly get the lifters out and/or give up material on the heads to make swapping the lifter possible.
It is also interesting to look at a Gen 1/2 block which is on the same bore spacing as a Gen 3/4. The pushrods seem to pass much closer to the piston on the LS platform leaving less meat on the block/heads to keep the head gasket gasket sealed again likely making rigidity a priority.
Old Aug 29, 2017 | 11:43 PM
wcsinx's Avatar
wcsinx
That picture really tells the story when you compare it to a gen 3. It's like the gen 3 has one continuous surface from one bank to the other. Whereas the gen 1/2 looks like a bunch of cobbled together bits that all just needed to make room for each other. Ain't progress great?
Old Aug 30, 2017 | 09:59 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
The Gen3/4 certainly looks cleaner.
The Gen 1/2 also has a 5 head bolt per cylinder vs 4 for the Gen 3/4. I know forced induction guys would love to have 5 and thus you can get 6 bolt versions from the aftermarket and the LS-X block. The water jackets in the Gen 3/4 also make for a cleaner.
It is amazing how casting processes and technology evolves.
To C5: replace lifters without removing heads?
