Interior Back Panel
Old Aug 31, 2017 | 11:44 AM
2ndvett01's Avatar
2ndvett01
Default Interior Back Panel
how do you remove the back panel to access the brake pedal switches?
Old Aug 31, 2017 | 02:56 PM
KCK8766's Avatar
KCK8766
Two torx at bottom of panel. Gently pry the fog/hatch bezel out and disconnect the harness, another torx is in there. Also remove the bezel for the temp sensor on the right side of steering wheel. Another torx in there too disconnect harness as needed. Now the screws are out. gently, pry the panel loose starting by the door and slowly working your way to the ignition. Gentle is the key here.
Some folks also go so far as removing the radio bezel. Google if you wish to do so.
Old Aug 31, 2017 | 03:01 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
if its the one I think you mean.....way back up under there is one of those fkn lock washer things like this on a metal stud
I know this because I had to lay up under there while parting out my car to get the damn thing out.....I think GM did this to **** you off...no other reason to use that type of fastener in that spot
Old Aug 31, 2017 | 03:10 PM
2ndvett01's Avatar
2ndvett01
Pewter 99. Thank you for the answer. The panel I'm questioning is the panel in back of the brake pedal. Panel has to be removed to access switches that affect the cruise control. BTW I also have a pewter vert..
To Interior Back Panel
