Who makes Cat delete pipes?
Old Sep 2, 2017 | 09:36 PM
dapopa9's Avatar
dapopa9
Default Who makes Cat delete pipes?
Who makes Cat delete pipes that bolt up to the factory OEM exhaust manifolds?
I have a track only car running stock exhaust manifolds but looking to remove both front and rear cats.
Looks like it would be pretty easy to unbolt the connection at the exhaust manifold, make a cut right after the rear most cats and then bolt/clamp in a plain pipe if someone makes it.
Old Sep 3, 2017 | 02:09 AM
dapopa9's Avatar
dapopa9
Also this is for '02 Z06
Old Sep 3, 2017 | 07:16 AM
vettenuts's Avatar
vettenuts
I think Borla makes a set. LG used to, but not sure if they still do.
Old Sep 3, 2017 | 12:02 PM
c4cruiser's Avatar
c4cruiser
Is the car licensed? If not, you might ask a local muffler shop to cut out the cats and weld in open pipes. You may have to trailer the car to a shop and let them know the car is used for "off-road use only".
Many shops won't remove working cats. If they would get caught, they could face a 5-figure fine. Just have to find a small shop that would do the work.
Old Sep 3, 2017 | 12:43 PM
dapopa9's Avatar
dapopa9
No. Car is off-road track only
Old Sep 6, 2017 | 10:13 AM
SocalC5Z's Avatar
SocalC5Z
If you take the pipes off the car and to a muffler shop they will usually cut them out and install straight pipes. My fabricator did mine and had no issues as long as he wasn't putting it back on the car.
Old Sep 6, 2017 | 06:44 PM
dbgoodwin's Avatar
dbgoodwin
Just out of curiosity... if you have an 02 z06 you shouldn't have but one set of cats, the rears. After 2001 they stopped using precats.
Old Sep 6, 2017 | 06:59 PM
dapopa9's Avatar
dapopa9
I don't have a picture of the bottom of my car but there are 2 bulges in the pipe just after the stock exhaust manifold nut/bolt flange.
1st(front) bulge is pretty small so I'm not sure if it is a cat, 2nd(rear) bulge looks like the cutout piece in the above pic from Dunlevys.
So I'm not sure if that is 1 or 2 sets of cats?
Old Sep 6, 2017 | 07:06 PM
dapopa9's Avatar
dapopa9
I found this pic online and I think(although could be wrong) mine look similar to this
Old Sep 6, 2017 | 07:16 PM
dbgoodwin's Avatar
dbgoodwin
That's an 01 H pipe.. if you look at the post a few replies back you'll see what an 02-04 should look like, with just the main cats.
Not that it really matters, probably what happened is the previous owner either had bad cats and bought a used 01 h pipe or he had headers and when he went back to stock put on used 01 parts.
Old Sep 6, 2017 | 07:20 PM
dapopa9's Avatar
dapopa9
also what part of the exhaust is Titanium? Just the mufflers? Or all these pipes?
Old Sep 6, 2017 | 07:28 PM
SocalC5Z's Avatar
SocalC5Z
Yeah you have what they call "pup" cats and like dbgoodwin posted, 2002 and later C5's usually didn't have them. Who knows what a PO may have done in the past. Maybe find a later exhaust like mine or you could punch out the pup catalyst substrate (PITA) and have the straight pipe mod done on the main cats. Doesn't make sense to pay a fab guy or muffler shop to do four straight pipes on this exhaust.
My fabricator welded a brace on the pipes after he cut the cats out one at a time to keep the pipes aligned while he welded in the straight pipe. That is the only correct way to do it off the car if you want it to align properly.
Old Sep 6, 2017 | 07:29 PM
SocalC5Z's Avatar
SocalC5Z
Just the muffler assembly including all the pipes are Ti. The headpipe and cats are not.
Old Sep 6, 2017 | 07:33 PM
dapopa9's Avatar
dapopa9
Yeah will probably just take it to a local shop and have them cut and then weld in straight pipes similar to what you did above.
Old Sep 8, 2017 | 07:39 PM
The Wrench's Avatar
The Wrench
I had a Bassini cat-delete pipe way back when. Had an x-pipe half way back and was a simple bolt-on to the rear muffler pipe flanges. Smelled so bad and backfired a lot; sold it years ago.
All the non-Z06 cars from '01 - '04 had the pup cats shown in the photo above. As mentioned, he probable took headers off and found a cheap replacement from a non-Z06. Less than 5 HP loss on the pups - but then cheap HP is hard to find!
DG
Old Sep 19, 2021 | 07:04 PM
Hotline's Avatar
Hotline
3rd Gear
Do you get any error does with the cats deleted like this?
Old Sep 19, 2021 | 07:19 PM
SocalC5Z's Avatar
SocalC5Z
I ran plug in SIM for the post cat O2's, so no CEL. Otherwise, you'll have that issue unless you tune it out. Also, smells pretty bad but worth it to keep a track car from melting down the cats.
To Who makes Cat delete pipes?
