Earlier I finished up replacing the front seal & crankshaft balancer on my 04. Still waiting on one more pulley to come in so I can do a test fire. I used a crank pulley install tool to push the balancer the majority of the way on to the crank snout. The Haynes manual says to put the old crank bolt back in after using the install tool & torque it to 240ft lbs. I know I had my torque wrench set correctly, but I ran out of threads before achieving that spec. I then removed that bolt & replaced it with an ARP with the included washer & thread locker. I torqued that bolt to 37ft lbs successfully as the manual said. Will everything be fine? I measured the distance from the crank snout to pulley before I put the ARP bolt in & the measurement was within spec of the manual. First time doing this job. Thoughts?
Thanks in advance,
-Matt
You probably ran out of threads because they ain't there anymore. Probably flattened. I torqued my arp bolt to 225. Try to get there but if it all the sudden feels easy before reaching torque, you probably damaged the threads in the crank.
..idk how that could've happened. There was no point where the threads felt easy after tightening. I just got to a point where it felt like it was maxed, like tightening any other bolt. The bolts/ threads never felt damaged/rung off/flattened. I know what a bolt feels like when you ring off the threads, gets extremely loose, I don't believe it happened. It's probably fine & im just over thinking it, I'll know when I get the last new pulley & test fire it.
Thanks in advance,
-Matt
Matt,
Is this a stock pulley from GM or an aftermarket?
What specifically did you use to push the new pulley hub onto the crank snout?
When using the ARP bolt, you use the GM procedure up until the point that you torque and remove the original bolt as you did. The ARP bolt is installed with their lubricant and tightened to a high torque value according to their instructions. The 37 lb-ft value is for the GM bolt and this is to seat the bolt prior to the rotation that is used to yield the bolt material. The 37 lb-ft and rotation in degrees is not used with the ARP bolt. Note that the ARP bolt is lubricated on the threads but also under the bolt head and washer. ARP doesn't recommend loctite.
If you tightened the ARP bolt only to 37 lb-ft, it will come out.
It's the Powerbond PB1117N balancer. I used the Lisle Installer tool 53760. It worked very well & like I said I was able to get the snout to pulley measurement within spec & line my markings back up. 37 ft lbs was all I could get on the ARP.. It won't go anymore. I might could get a couple more turns with a long cheater pipe on the end of the breaker bar, but it sure does feel tight. & I only used the lubricant that ARP sent I didn't use a separate loctite. I also used the washer that was in the pack too because the ARP was longer than the stock GM bolt. I didn't put the lubricant on the washer or bolt head of the ARP, I did not know to do so. What torque spec does the ARP need to achieve? Hopefully I won't have any problems
how much torque did you get before you put the ARP bolt on? you never mentioned it. Had to be over 200? no?
Hopefully..when I didn't hear my wrench click to 240 I then reset it down to 200 & still didn't hear a click..should I have put the cheater pipe on it & kept going? It feels so tight that I don't want to force anything & mess something up..
Like I said It doesn't feel like I ruined any threads, just feels like the bolt is maxed out & can't go anymore. I feel like I didn't achieve 240 on the old bolt because I used the Installer tool to press it on most of the way. From my understanding torquing the old bolt to 240 is just another way to pull the balancer into position/seat it on to the snout far enough. I must've just used the install tool longer than most to get it pressed on & that's why I couldn't hit the 240 on the old bolt because it was already very close to the proper distance off the snout. Could be wrong
Well guys I just went & threw the torque wrench back on it for the heck of it, tightening it from the top of the engine bay with more leverage & got the ARP to click at 220ft lbs. I don't know what happened yesterday.
OK, that's better. At 37 lb-ft it would like spin out.
think it'll be ok that I didn't put the lubricant on the washer/back head of the bolt? Should I pull it back out & put it on it?
By lubricating the threads of the bolt, as well as the washer, etc, is that you achieve an ACTUAL 240 ft/lbs of torque on the bolt. The lube eliminates the friction between those parts, that MAY prevent you from getting to an ACTUAL 240 ft/lbs.
okay, I just pulled it/put the lubricant on it & hit 240ft lbs fairly easily.
I put mine to 240ft-lbs and used ARP assembly lube instead of Loctite on the threads and the washer surface. A lot of people have used different strategies, but most seem to have worked. Best way to get the leverage for the torque is from that top as you have discovered. Just gotta eat your Wheaties.
I was surprised to read in the instructions ARP wanted the lube put on the threads.
I put the lub under the head of the bolt, and on the washer, but I did put red loctite on the threads. Got the bolt to the 235ft/lb that the instructions said.
I really didn't want that thing coming out since it was such a pain to do.
Yes it definitely is a pain of a job to do. Pretty labor intensive, but also rewarding after completion. I put the ARP lube on the threads, under the washer, & under the head of the bolt. Torqued it to 240ft lbs using a cheater pipe on the torque wrench (pipe was part of the handle to my floor jack). Since then I have got the car all back together, all the belts lined up & it runs smoother than before. I took this opportunity to do a great deal of preventative maintence, maybe even went over board with it. Those new plugs & wires sure made a difference as well. I went from spending a little over $100 on the balancer & arp bolt to totaling over $2k in parts by the end of it...lol but I figure I won't have anymore problems for a very long time with all that I replaced. Not to mention how much $$$ I saved by doing it all myself.
