Help! My C5 just QUIT!
Old Sep 4, 2017 | 02:16 PM
GEMcLean's Avatar
GEMcLean
Default Help! My C5 just QUIT!
2004 Torch Red Coupe. 130,000 miles. Automatic.
Was driving along and it just quit! Everything. No lights, engine, hvac... nothing.
Just like disconnected battery. Tested battery, it is good. Cleaned terminals and reconnected. Worked for a bit, then revved a bit (2200 rpm) and it quit again. Got out of the car and shut the door, and then it would start again.
Anybody have this happen to you?
Thanks!
Old Sep 4, 2017 | 03:22 PM
MSGE's Avatar
MSGE
Did you mean to say, "wouldn't start again"???
Otherwise I'm confused.
My first thought was fuse, but you said it started and ran to 2200 rpm. So that's not likely.
Maybe a short in the ignition area?
Or, could be something nasty going on with the engine control module. (Is it called drive train control module in c5? DTCM?)
Old Sep 4, 2017 | 03:25 PM
MSGE's Avatar
MSGE
If you've got a good buddy with a similar ride you could try swapping in the ecm from his/hers to yours.
That would be a pretty easy way to rule that out.
Note: That's my opinion as a computer technician and not as a mechanic. lol
Old Sep 4, 2017 | 05:54 PM
GEMcLean's Avatar
GEMcLean
Here are ALL my codes:
PCM P0463 HC (fuel gauge also is intermittent)
HVAC B0367 H
RDCM B2285 H
RFA U1000 H
RFA U1064 H
That's all, folks. No other codes to pull.
Old Sep 4, 2017 | 06:36 PM
GEMcLean's Avatar
GEMcLean
I had the battery load tested today and it tested good.
We have a great 'vette shop here in Tampa, will call them tomorrow.
Thanks for the suggestions.
Old Sep 5, 2017 | 01:27 PM
MSGE's Avatar
MSGE
Originally Posted by 8VETTE7
Throw parts at an electrical problem without knowing the cause of the electrical problem gets expensive REAL fast and is no way to address ANY problem.
Would love to know where you operate out of so I can be sure NOT to take my computer to you!!!!!!!!!!!!
LoL, thus the disclaimer. It's cheap for us because we always have spare parts!
Also, I did say "if you have a friend near by" to test out a known good part.
And to answer your question: The Military.
We don't get much training in all honesty.
Old Sep 5, 2017 | 02:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Swapping in a PCM and or BCM is a lot more involved than just un-plugging and plugging in the modules. Besides, he said that more than just the engine was not working. The PCM has NOTHING to do with the lights. You have to perform a GM HAND SHAKE PROCEDURE so the BCM recognizes the PCM.
"(Is it called drive train control module in c5? DTCM?) ???????????
Powertrain Control Module (PCM)
GEMcLean
If the car turned OFF just like you turned the ignition key to OFF, I would highly suspect that you have a BAD or FAILING ignition switch. When they fail the usually don't leave any tail- tell DTC (because the car thinks you turned it OFF like normal.
You really need to better define the statement: (Was driving along and it just quit! Everything. No lights, engine, hvac... nothing. )
If you turn the headlight to ON do the headlight doors pop up and lights come on? Horn work?? Emergency flashers work???
Bill
Old Sep 5, 2017 | 03:00 PM
Scotty_Z06's Avatar
Scotty_Z06
I had something similar happen to mine about a year ago. I found that the positive lead from the batter that goes to the fuse box beside the batter was loose. I tightened it down, cranked right up, and never had that issue again.
Old Sep 5, 2017 | 03:15 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXCELLENT recommendation!! That is called the B+ connection for the fuse box. There is also one like it on the passengers fuse box.
Bill
Old Sep 6, 2017 | 08:27 AM
GEMcLean's Avatar
GEMcLean
Default Beam Me Up, Scotty_Z06!
Bless you! Bless you! Bless you!
I opened up my fuse box next to the battery and was able to turn the nut on the positive post with my pinkies!
Took my trusty 13mm socket and tightened that sucker.
Time will tell whether that is the only issue, but that was a wonderful call.
Another great result of being on this forum. A blessing to all of us.
Also thanks to Bill Curlee, your insight is always right on.
Old Sep 6, 2017 | 04:39 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It was Scotty_Z06 who hit the nail on the head... I just sent the pictures.
Well done Scotty_Z06
Old Sep 6, 2017 | 06:05 PM
Scotty_Z06's Avatar
Scotty_Z06
Glad I was able to help. Let's just hope that fixes your issue. It was really embarrassing having to push my car off a major road by myself.
Old Sep 15, 2017 | 02:54 AM
MSGE's Avatar
MSGE
Wow! That was incredibly specific help!
Truly, hats off
Old Sep 15, 2017 | 07:46 AM
runner140*'s Avatar
runner140*
The information from the major players on the Forum is so far superior then most dealerships or shops.
To Help! My C5 just QUIT!
