Fuel Pump Part Number
Old Sep 6, 2017 | 04:37 PM
KS Rebuilder's Avatar
KS Rebuilder
Default Fuel Pump Part Number
I am looking at buying a new fuel pump assembly and I came up with 2 part numbers. Old part number 19330864 and new part number 19352603. Is there any difference in the 2? I would assume that the new part number has upgraded the fuel level sender part. I have found both for sale with the old part number being a little cheaper. Thanks in advance for your help.
02 Z06
Old Sep 6, 2017 | 04:44 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
make sure whatever you do that it comes with the correct gasket
the old number/part is discontinued if that helps
Old Sep 7, 2017 | 08:07 PM
KS Rebuilder
Wii do. Does anyone have the information on the pumps?
Old Sep 7, 2017 | 09:04 PM
StingrayRebel's Avatar
StingrayRebel
are you looking for just a fuel pump or are you trying to get the whole assembly (bucket, sending unit, level sender, etc)?
Old Sep 8, 2017 | 12:02 AM
KS Rebuilder
Yes I need the whole assembly. The dyno (hack) shop that I first worked with said I needed a high flow external pump and disconnected and cut off/plugged the tubes coming out of the factory pump. So major vapor lock happened with the external. My first set up was a 255 pump with a boost a pump. They burned that up by doing 3 quick pulls on the dyno. My 3rd set up was the 04 tank install and aeromotive stealth pump and it cavitated right away and now won't hold fuel pressure high enough to siphon the fuel to the drivers side tank. This was several years ago and I haven hardly driven it since. Had the car since 05 and put 1,000 miles on it.
Old Sep 8, 2017 | 12:23 AM
StingrayRebel
dang... well it sounds like you are going to build a fuel system and just mainly need the sending unit, have you tried ebay?... I bought a complete spare driver side tank with the sending unit and everything for like $120 and used it to build a different setup while the old setup was still in the car... Marc at vettenuts is also a good source if you decide to go with a used unit
Old Sep 8, 2017 | 01:25 PM
KS Rebuilder
I am getting a little old and don't like getting under the car much so I am looking to buy a new unit and I really don't want to risk the problems of a bad fuel level sender. Will probably sell the car in the not to distant future and would like to tell the buyer that it was done right.
Update: Purchased new discontinued pump. Thanks for input.
To Fuel Pump Part Number
