HVAC Code Differences
Old Sep 13, 2017 | 02:55 PM
huesmann's Avatar
huesmann
Default HVAC Code Differences
So there are 3 codes for each HVAC actuator (left and right):
Actuator Feedback Short to GND
Actuator Feedback Open
Actuator Out of Range
What does each of them mean, practically speaking, as an indication of what the actual issue is (in plain English) with the actuator?
Old Sep 13, 2017 | 04:43 PM
rrwirsi's Avatar
rrwirsi
Excellent question.
Old Sep 14, 2017 | 12:00 AM
RLDaily's Avatar
RLDaily
Actual issue? You need a new blend door actuator. I just replaced the one on the passenger side, about a 4 hour job and $130
Old Sep 15, 2017 | 11:47 AM
huesmann's Avatar
huesmann
As I understand it, there's a plastic gear inside that can get stripped. So does that produce all three codes?
Old Sep 15, 2017 | 12:57 PM
huesmann's Avatar
huesmann
Yeah, I may have seen that. I guess what I'm wondering is: does the cracked gear trigger all of those codes? That is, if I remove the actuator and find a cracked gear, and then replace that gear, will it keep all three codes from coming back?
To HVAC Code Differences
