Paging C5 Tech: Windshield Washer Prob
Old Oct 6, 2002 | 07:59 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Paging C5 Tech: Windshield Washer Prob
Okay, so I was stuck in gridlock a few Fridays ago about an hour after tornadoes hit Indy and flipped the wipers on to wipe off some mist still coming down. As I flipped the switch up, the washer button on the end shoots out across the car with the 2 springs that are under it!! This is the 2nd time I've had this problem, am I the only one?
Anyway, the springs were under the passenger seat and I couldn't stop the car to search since we were crawling along the interstate in first gear. The problem is that when the switch is off, the washing mechanism is constantly on. It would be nearly and hour before I had a chance to get pulled off the road to fix things. Of course by now my washer motors had been running forever and I was long since out of fluid.
Here's my problem. Now that I have the fluid refilled, the washers don't work. It sounds like the pump motors are running when I push the switch on, but no fluid comes out. Help! Does anyone have an idea how to solve the issue? Thanks in advance.
Old Oct 6, 2002 | 09:49 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Paging C5 Tech: Windshield Washer Prob (BQuicksilver)
There is a good chance the the washer pump went bad...Much like a fuel pump,the pump being submerged in a liquid actually keeps it cool and prevents it from overheating.The washer pump is located at the bottom of the washer tank :yesnod:
Old Oct 7, 2002 | 01:11 PM
powderski13's Avatar
powderski13
I had the washer button come off my 2002 vert when it was parked in the garage. I was lucky enough to find the 2 small springs and put everything back together. I now have a small piece of black electrical tape over the end to make sure it doesn't happen again. When the button flys out, the wipers and washer are continously running :( :flag
Old Oct 7, 2002 | 01:31 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Paging C5 Tech: Windshield Washer Prob (powderski13)
my wipers suck azzz :mad ...don't squirt water..etc...
Old Oct 8, 2002 | 06:28 PM
BQuicksilver
Default Re: Paging C5 Tech: Windshield Washer Prob (C-5 TECH)
Thanks for the help, I really appreciate it. I assume this wouldn't be something out of warranty or too difficult to avoid the GM dealer handling it?
To Paging C5 Tech: Windshield Washer Prob
