Mn6 shift issue bad pilot bearing?
i just recently started having this issue with my 98. When I try to upshift it is very hard to get into gear. It downshifts great! So I went and bought a tick master cylinder and installed it. No change. Now my car sometimes when pulling out as soon as I start letting the clutch out it will start grinding. Is this a transmission issue or a bad pilot bearing?
thanks
tom
Try this: Jack the rear wheels off the ground. E-Brake OFF. Start the engine, release the clutch in 1st gear. Depress the clutch. See if the wheels stop driving.
If they still rotate, can you easily stop both of them by hand.
If not, your clutch is not fully releasing and that will make shifting difficult.
Change that trans ATF and see if that makes an improvement!!
Bill
