Lifter noise with cam
Old Sep 23, 2017 | 11:33 PM
T5Mika's Avatar
T5Mika
Default Lifter noise with cam
I swapped the mildest truck cam from comp, z06 valve springs, LS2 timing chain, and a 25% UD pulley in my '01 LS1. It runs fine and pulls exactly as I expected, but it developed a pretty loud lifter knock when warm. The valve train has the usual Singer tick when cold, but after a few hard pulls it starts knocking so hard at idle that it can be heard hood closed. The knock sounds like a lifter knock as opposed to rod knock.
I was being careful with the oil pick up O-ring, but the oil pressure when hot is at 25psi at idle (60 at max).
I used stock rods and rockers, and tried to torque them properly.
The idle is very lopy when hot, smooth when cold.
The oil is 5w30 Mobil 1.
The engine has 55000 miles on it.
Ideas to start debugging this?
Old Sep 24, 2017 | 08:03 AM
vettenuts's Avatar
vettenuts
Is the noise coming from all the lifters or can you isolate to one or two? If one or two, check those rockers for any abnormalities. Check and make sure that oil is coming up the pushrod. If you used stock pushrods, roll them on a flat surface and make sure they are straight.
Could be many things, but I found even as careful as I was during my first cam swap I got one small dirt fragment in the oil gallery for the lifters. Only found it because I had borrowed an articulating borescope from work. So an small dirt particles (pieces of gasket, etc.) that might have gone into the lifter gallery can cause this issue.
Old Sep 24, 2017 | 10:07 AM
tbrowne's Avatar
tbrowne
A new cam will normally require careful measurements to determine the correct pushrod length for that particular cam. Chances are pretty good that the stock pushrods are too short for your build. In some instances, the exhaust pushrods will be slightly different than the intakes. Get a good pushrod checker and measure them so you know exactly what length you need. pushrods can be purchased in any required length. You'll also need an 8 inch caliper to read the measurements obtained. Without accurate measurements, you're just guessing.
Old Sep 24, 2017 | 06:33 PM
T5Mika's Avatar
T5Mika
Now I'm starting to suspect exhaust leak...
I had to loosen the H-pipe to manifold flange to remove a starter bolt. The exhaust snaps and creaks now in hard acceleration, and the tap tap tap sound is louder under the car. The rockers sound ok with a stethoscope. I bet the exhaust is not properly seated. I think I'll try the old seafoam trick to see if the flange leaks.
Old Sep 25, 2017 | 02:09 PM
T5Mika's Avatar
T5Mika
And here's the sound, in the end of the video. ka-noc, ka-noc, ka-noc...
Old Sep 28, 2017 | 12:23 PM
SaberD's Avatar
SaberD
if pushrod length is not an issue, I would give it time. sometimes air can get trapped inside the lifters and takes a while to work its way out. This is why a lot of people suggest soaking the lifters first.
To Lifter noise with cam
