Severe rear wheel vibration
2000, auto, no mods, factory wheels, tires need to be replaced.
This is an intermittent issue. When traveling at highway speeds and I accelerate, I get a tremendous wheel hop on the right rear wheel, until I let off the gas. The car shakes and the right rear is very violent. Almost like I'm running over a cobble stone street on that side of the car. I can't swear to it but I believe it happens in 3rd or OD. I will need to get a better pattern on it.
Has anyone seen anything like this before?
there should be no movement
Sounds like a plan. I'll try that this weekend.
- IS MY C5 WHEEL BEARING BAD: https://www.corvetteforum.com/forums...diagnosis.html
You can try this too while you have the jack out:
Jack up One REAR wheel (other wheel on the ground) Trans in N and E brake OFF.
Attempt to rotate the of ground Rear wheel. There should be some force to over come as you are slipping the limited slip clutches to break that wheel free. NOTE THE FORCE that it takes to break it free!!
Do the exact same thing to the other rear wheel.
The force to break either wheel free should be the same and feel the same. If one is much less than the other, you have limited slip clutch issues or the limited slip clutch beleview spring is broken.
Could also be a damaged output shaft.
Give all that a try and see where you are.
Bill
Bill
Tank you Bill. My first inclination was a posi unit issue or an axle shaft issue, due to the severity of the vibration. I'll get her up in the air this weekend and poke away.
