AC compressor replacement question
Old Sep 28, 2017 | 10:42 AM
chris308's Avatar
chris308
Default AC compressor replacement question
So I'm getting ready to fix my compressor that I have been putting off forever now. I have RoccoC5's write-up printed up and will be using as a guide.
Just wondering from the others that have done this job already, any new tips or tricks discovered, something you could or would have done differently?
I will also be replacing my condenser at the same time as well.
Old Sep 28, 2017 | 11:16 AM
SaberD's Avatar
SaberD
I would take it to a shop without the AC belt on to get it charged. Those cans you buy at the auto parts store are really difficult to get a good seal on the connector for charging. I lost a lot of refrigerant while trying to fill mine due to the bad connection. If you lose any, then it's really difficult to know how much you are putting in the system.
Old Sep 28, 2017 | 10:24 PM
chris308's Avatar
chris308
Do you mean driving to the shop un-belted then reinstalling the belt once there?
Old Sep 28, 2017 | 11:19 PM
LoneStarFRC's Avatar
LoneStarFRC
Make sure one of the cans of refrigerant that gets used to recharge the system after repairs contains ICE-32, or its direct equivalent.
Old Sep 28, 2017 | 11:51 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
good luck!
Old Sep 29, 2017 | 07:05 AM
chris308's Avatar
chris308
Check, thanks!
Originally Posted by pewter99
good luck!
That doesn't sound encouraging lol!!
Old Sep 29, 2017 | 07:38 AM
Simtech's Avatar
Simtech
I replaced my compressor in 2015. The kit was fairly cheap, about $300. The hardest part was flushing all of the crap out of the system. I squirted solvent in with a large syringe and then used air to blow it through the system. Took over 2 gallons before it started coming out clear. I then pushed A/C system cleaner through it just to be safe. After that I pulled a vacuum on it and then charged it. Its been working great ever since.
Good Luck, Its really not that hard if you are a little mechanically inclined
Old Sep 29, 2017 | 08:08 AM
Rob 02's Avatar
Rob 02
^If the OP is changing the condenser it probably wont require as much cleaning.
I got a $100 compressor off Amazon two years ago and it is running strong. Some compressors come with oil already in them and some don't. If not make sure you add oil. Change the orifice tube (of coarse).
I use a meat thermometer in the center vent verify it's working properly.
Old Sep 29, 2017 | 09:35 AM
SaberD's Avatar
SaberD
I would have them install it after they fill it with refrigerant because they will need to run it to check the pressure. I'm just not sure if it's ok to run the compressor without refrigerant even if the oil is already in there. Maybe someone else can chime in on this.
Old Sep 29, 2017 | 02:35 PM
Carl Timonen's Avatar
Carl Timonen
The compressor clutch will not engage without freon because of the pressure switch.
Old Sep 29, 2017 | 05:19 PM
Rob 02's Avatar
Rob 02
You could just unplug the two pin connector going to the compressor to keep the clutch from engaging or simply turn off the HVAC.
Old Sep 30, 2017 | 02:27 AM
Frame77's Avatar
Frame77
exactly.
mount everything including the belt and have it refilled.
I used the same write-up. Not a hard job.
To AC compressor replacement question
