PCV hose...2000 Corvette
Old Sep 30, 2017 | 01:54 PM
1quikta's Avatar
1quikta
Cruising
Default PCV hose...2000 Corvette
I need a little help here guys, I have been searching for over an hour and I did find the hose GM part#12558673. I can not find the part numbers for the connections to the right valve cover (sure i could use regular hose) and also the one that connects to the intake manifold. That is the one with the piece that bolts on with the wire. Any and all help is appreciated.
Thanks,
Chris
Old Oct 4, 2017 | 04:25 PM
SaberD's Avatar
SaberD
I just picked up a small section of hose from the auto parts store. works great and won't rot like the stock elbow. You have to buy the whole hose with all the connectors if buying new as the components are not sold separately.
Old Oct 5, 2017 | 02:09 PM
03WhiteConv's Avatar
03WhiteConv
Take a good look at the whole thing if you haven't yet. It might be gone behind the intake too. This is how I fixed mine for just a few dollars. The Frankenstein part is hidden behind the manifold so the rest looks original. Head down to your local parts store and look in the Help! section.
https://www.corvetteforum.com/forums...be-repair.html
To PCV hose...2000 Corvette
