tpms
Old Oct 7, 2017 | 05:01 PM
12andrew3's Avatar
12andrew3
4th Gear
Default tpms
hi ,i recently bought 4 tpms valves for my 1999 c5 ,ive tried to learn them to the car using magnets with no success ,ive contacted the supplier they said you dont learn them using magnets but with a [ diagnostic tool ] firstly how can they supply the valves for a c5 if you dont learn them the way a c5 is designed to learn them ,also where can i get them learned hope someone can help cheers
Old Oct 7, 2017 | 07:07 PM
rkj427's Avatar
rkj427
Pro Mechanic
Welcome to the forum!
Check out the C5 General area for info. on TPMS.
You may have a local tire shop help you out too.
Old Oct 7, 2017 | 07:37 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Welcome aboard!
Old Oct 7, 2017 | 08:54 PM
FX VETTE's Avatar
FX VETTE
Welcome to the CF!
Old Oct 7, 2017 | 10:00 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum!
If the magnet is not working, hopefully the tire installer can help. As was also mentioned by rkj427 try a search. Good luck.
Moving to C5 Tech.
Old Oct 8, 2017 | 04:09 AM
12andrew3's Avatar
12andrew3
4th Gear
Originally Posted by 8VETTE7
The C5 training procedure for TPMS does NOT specify that the TPMS be made to transmit using a magnet. The Procedure simply requires that a TPMS can be forced to transmit on demand. Schrader and ACDelco TPMS just happen to use a magnet to force the transmission. Other manufacturers can use any procedure of their choice. Some use a technique of letting air out of the tire to force the transmission and others use electronic tools to force the transmission.
When ever you purchase an after market TPMS for the C5 you, or the person training the TPMS to the car, need to know what technique is required by the manufacturer of the TPMS and use that technique.
As far as getting your after market TPMS programmed to your C5 you are going to have to identify the needed technique and then find someone that can do that process while using the DIC initiated training procedure.
hi , thanks for the reply,i didnt know this so much appreciated ,i will search for a garage with a diagnostic tool i need thanks again
Old Oct 8, 2017 | 07:28 AM
vettenuts's Avatar
vettenuts
Who was the supplier/manufacturer of the sensors? I just installed four new GM and simply used the magnet.
Old Oct 8, 2017 | 03:48 PM
12andrew3's Avatar
12andrew3
4th Gear
hi ,thanks for the welcome ,just hope i can find someone to do it
Old Oct 8, 2017 | 03:52 PM
12andrew3's Avatar
12andrew3
4th Gear
hi,they were from a German company called auswuchtwelt on ebay ,i didnt know they wouldnt learn the magnet way ,wish i had bought some from GM now tho {live and learn}
Old Oct 11, 2017 | 01:08 AM
CactusCat's Avatar
CactusCat
Just drop by Discount Tire and see if they can help. Easy peasy.
Old Oct 11, 2017 | 03:29 PM
CactusCat's Avatar
CactusCat
My bad. I had no idea the OP was in GB. Hopefully, he got the drift and should be able to go to just about any tire store and get this done.
To tpms
