Oil Catch Can...
Old Oct 7, 2017 | 08:23 PM
Bomar'sC5's Avatar
Bomar'sC5
Default Oil Catch Can...
I have an oil catch can laying around that I had on a 2008 Challenger SRT8, other than me fabricating the bracket to make it bolt on to the head. Is there any difference in theory between this and a catch can you order on line for the corvette? I looked at the hook ups and also the inside and actual structural design of them an they seem basically identical. Can anyone give me their input? Would I be hurting anything giving this a shot?
Old Oct 8, 2017 | 02:57 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Not as long as it's plumbed right....
Look up --PCV Oil Catch Cans Back in Stock, CCA in the CF search area. I think there is directions for install....Lot's of info in CF search area 4 catch cans also
mike v
Old Oct 8, 2017 | 08:38 PM
feeder82's Avatar
feeder82
Elite Engineering's web site has great instructions and diagrams, should make it easy to figure out if it will work
Old Oct 8, 2017 | 10:49 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
A catch can is a catch can ---as mentioned as long as it is installed correctly and is installed on the PCV plumbing side that is going into your manifold---it will work and do it's job-----Any LS engine is notorious for oil injestion via the PCV into your intake tract--This oil contaminates your air intake charge and can foul spark plugs -cause detonation and carbon up your intake manifold and T-Body Do it !!
To Oil Catch Can...
