Instrument panel
Old Oct 15, 2017 | 07:35 AM
subcode1's Avatar
subcode1
Default Instrument panel
Took dash apart to install blue LED for HUD. Got bulb kit from west coast. While apart I wanted to change the 14 bulbs in the back. Did not want to go with LED so I don't deal with polarity issues. Also figured put new UV bulbs while in there.
Looked at almost every post and simply could not find the Number for the 14 bulbs and if they are all the same. could not find part # or even where I can get the UV bulbs.
My service manual tells you how to take apart but no numbers the schematic identifies what for but again no numbers.
Does anyone out there know what the bulb numbers are?
Some items I saw posted have links but none work?
Thanks for any help
Old Oct 18, 2017 | 08:32 AM
Tulsaeasyrider's Avatar
Tulsaeasyrider
Thanks for any help
I don't know, but suggest you go to a dealer/parts dept. to obtain appropriate bulb identification. Good luck!
Old Oct 18, 2017 | 11:05 AM
Robrote's Avatar
Robrote
To Instrument panel
