Misfiring Now what
A few weeks ago I was just going to get some gas when this SRT4 avenger was in front of me with a fart can on it driving like (explicit adjective). He got stopped at a light so when it turned green I gave him the business. He flipped me off for my trouble. Anyway went straight to the gas station got gas started it up and realized my car was missing like hell. A few days later I got plugs and cylinder 6 was black and gas soaked all other plugs were fine. Got a new wire set and a coil pack just in case changed everything and still missing. I went under the hood and checked on the grounds that Bill Curlee has went in depth about causing problems and they were pretty clean. For good measure I shined them up and still missing.
When I bought the car after poking around on the forum I looked at the PCM and it looked as it had been hit with some battery acid nothing to bad but it still had the AC Delco Battery that leaked in there. Immediately cleaned all that up and got a yellow top. That thing went crazy on me and lasted a little over a year. If I did not drive the car everyday the battery would die. Took it back to Sam’s club and got a Duracell AGM battery. Have had it in the car for a few months without problem until it started missing.
When driven The car is throwing all kinds of codes most are loss of communication codes. It is missing to the point of almost stalling. It has a heavy odor of gas like cylinder 6 is still not firing. I don’t want to drive it anymore because I don’t want to hurt it.
It is a 2002 auto the only thing I have done was change to Z06 shocks and put a BBK CAI on it and threw a tune on there from a super chips handheld tuner that I have since removed. I miss my car can somebody point me in a direction on where to go next.
PLEASE list all those DTCs. It will tell us a LOT!!
Before you make the list,,, Clear ALL of the DTCs and then list the ones that come back. Make sure that you read them without turning off the ignition.
bc
BCM B0508,BO503
PCM PO300,P0200
RFA U1000,C2105,U1096
RDMC U1064, B2285,B2283,B2265
LDMC, B2284,B2282,U1064
IPC U1040,U1176
BCM B0508,BO503
PCM PO300,P0200
IPC U1040,U1176
LOL!!!!! See, I told you that it would work! PCM P0200!!!
That means that the COIL primary 12 VDC is not working. There are TWO fuses on each bank. Two for the drivers coils and two for the passengers coils.
Check them. 16, 18, 22
If the fuses are good, check the VOLTAGE at each of those fuses to GROUND using the test points on top of the fuses.
BC
That will be the cylinders that are having issues.
SPARK, FUEL, AIR or COMPRESSION
Something is missing. Just got to figure out whats wrong.
Bill
