Hi gents. Thanks for taking the time to read my post. Ive pulled the trigger on swapping my 2002 auto to a manual from a damaged 99 FRC.
I have parts coming from a donor car excluding drive axles and the bell housing. I planned to reuse my own. I understand the auto bell housing is thought to be a bit stronger than the two piece.
Electrically speaking, I understand Ill need a trans harness from an 01 up.
Any additional advice you guys could give would be great. ill put a write up together for everyone in the end.
