CV Axle Help
Old Nov 8, 2017 | 08:07 AM
DKS2K's Avatar
DKS2K
Default CV Axle Help
I have a turbo 1997 c5. Are the left and right side axle the same? Will the C5Z axle work on my 97'? What year of the C6 axle will work on the base c5?
Old Nov 8, 2017 | 08:15 AM
Moved to C5 Tech.
Old Nov 8, 2017 | 08:52 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
OEM C5/C5Z axles are the same and are pretty much the best option until you go with the high dollar replacements from someplace like G Force or the Drive Shaft Shop.
Doesn’t sound like you need to replace them unless the boots are slinging grease everywhere.
Old Nov 8, 2017 | 09:02 AM
DKS2K's Avatar
DKS2K
I do need to replace my axle. What year of the c6 axle work?
Old Nov 8, 2017 | 09:15 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
C5 and C6 axles are all the same. The C6 axles are not stronger.
Popular belief is that the C5 axles are stronger than the C6 axles, though I haven’t seen any technical data to back this up.
I use OEM C5 axles on my race car and have no issues.
Old Nov 8, 2017 | 09:17 AM
feeder82's Avatar
feeder82
C6 axles won't fit
Old Nov 8, 2017 | 09:22 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
Really? I had no idea. I seem to remember that they are the same.
What is different? The output shaft spline is the same. The hub spline is the same.
It is not my intention to give incorrect information.
Old Nov 8, 2017 | 10:43 AM
feeder82's Avatar
feeder82
you are right I am wrong my bad, SORRY
I looked at some part numbers
To CV Axle Help
