C6 Knuckles???
Old Jun 25, 2019 | 11:01 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Originally Posted by gimp
If there's no sustained track time, the C6 Z06 brakes are only there for decoration, too. The weight penalty - rotating unsprung weight - is hopefully worth it.
I disagree with that as I found C5 brakes lacking. It would be a nice upgrade on a street car. If you're going for track time go with something better than C6 Z06 brakes.
Old Jun 25, 2019 | 11:37 PM
gimp's Avatar
gimp
You were able to fade stock brakes on the street? How? Repeated strong braking isn't a normal street maneuver. A simple pad upgrade makes it damn near impossible unless you're driving like a crazy person.
I switched from stock size rotors to a wilwood BBK setup and found absolutely zero difference on the street.
Old Jun 25, 2019 | 11:40 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Yes mountain run with pad upgrade. Brembo 4 piston on 13" rotors was very much worth it.
Old Jun 25, 2019 | 11:49 PM
gimp's Avatar
gimp
/shrug
I'd recommend downshifting for downhill runs, tends to keep the brakes happier; regardless, a pad upgrade is all you need, as evidenced by the fact that your rotors are only a teensy bit bigger than stock. C6Z rotors are a hair under 14", significantly larger - and significantly heavier.
Old Jun 25, 2019 | 11:59 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
/shrug
I was and actually the rotors were the same size 322mm/12.8". Feel was just never great on C5 calipers. I tried Hawk and Performance Friction pads. Loved the same Performance Friction pads on my C4 with the 96 PBR calipers and I wasn't pushing the C5 that hard.
Old Jun 26, 2019 | 12:03 AM
gimp's Avatar
gimp
So it was just you not being happy with the feel, rather than a need to get big brakes to avoid fade, right?
Old Jun 26, 2019 | 12:05 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Both
Old Jun 26, 2019 | 12:46 AM
gimp's Avatar
gimp
The rotors are the same size, and a better caliper design isn't going to prevent fade, so to prevent fade you changed out the pads, and to improve feel you changed out the calipers. Right?
Old Jun 26, 2019 | 01:28 AM
Rob 02's Avatar
Rob 02
Originally Posted by Asterios Anagnostou
Reviving an old thread here. Hey Rob, I just did this swap yesterday and it took me no more than three hours with the right tooling. If you're running the c6 Z06 brake system, why not just swap the knuckles out? I do spirited driving and canyon carving and sometimes hit the brakes pretty hard. The c5 knuckles weren't designed for that much stopping power and so they flex and, under the right conditions, break. So, with the c6 knuckles on there, that's one less thing for me to worry about. I know I have the right parts paired together, you know?
You can find them pretty cheap nowadays. There are some Corvette part out sites that sell the front pair for about $100. Maybe I'm paranoid, but I don't want there to be any question when it comes to braking if I'm going to be doing any more than mild street driving. Just my 2 cents.
Who knows, you may not even have the car anymore!
I have been swamped projects lately and haven't had much free time. I don't think I can brake the stock knuckles doing what I'm doing. I'm in Jax Florida which is flat, the roads are straight and my car is an automatic, however if I'm ever in that deep, mechanically, for whatever reason I may swap the knuckles.
In the beginning of this, I was more concerned about the tie rod mount arm possibly providing better steering (sharper turning radius and better road feel via a shorter arm).
I originally wanted the C6 Z06 brakes because I thought the stock ones looked tiny with the C6 Z06 rims. After driving on I-295 & 95 where traffic often flows between 75-80mph, making frequent lane changes and maneuvering out of blind spots, I noticed substantial brake fade.
That is when I decided to pull the trigger and purchase a set. After installing them I noticed a huge difference. Not just in brake fade but in the the response to the brake pedal. These things really grab.
The un-sprung weight difference isn't much. I don't hear anyone complaining about them. When carbon rotors become more affordable I may get a set. I noticed brake technology has come a long way since '97, even for family sedans. The Corvette is supposed to be a performance car so why not keep up with the times.
Old Jun 26, 2019 | 01:43 AM
Rob 02's Avatar
Rob 02
/shrug
I wouldn't say significantly heaver but the wheels and tires are because they are significantly wider. With the rest of my suspension being essentially C6 Z06 why leave out the brakes?
Old Jun 26, 2019 | 02:59 AM
gimp's Avatar
gimp
Because it's added cost you don't need. Wanna spend the money? Go for it. I'm not here to tell you it's a bad brake kit, just saying you don't need big brakes unless you're at the track. Or for looks. If the looks are worth the cost then it's an easy decision.
Old Jun 26, 2019 | 08:02 AM
Rob 02's Avatar
Rob 02
The whole car is an added cost I don't need but I like it.
Old Jun 26, 2019 | 04:32 PM
  #33
gimp's Avatar
gimp
Then fantastic! Put on em big brakes. They do look way better.
Old Jun 26, 2019 | 05:07 PM
  #34
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
OE replacement pads on the Brembos, they were the Porsche 993 Big Red calipers. I added heads and cam, and never a fade problem. Next owner tracked it at Little Dega and loved the brakes on the OE pads.
Old Jun 26, 2019 | 05:26 PM
  #35
Rob 02's Avatar
Rob 02
I like the way the Brimbo's com off for service. I have the earlier PBR calipers with the pins. The pins are made of some really soft steel. I will probably go with one piece pads if I ever wear out the padlets.
