Odd problem with FRC this morning
Old Nov 16, 2017 | 11:13 AM
Shaolin Crane's Avatar
Shaolin Crane
Default Odd problem with FRC this morning
Been driving it every day for a few weeks now, today took it to work as normal, stopped off for a rockstar and when I cam back out I noticed a long green wire hanging from under the radiator support, looks like it's scraped on the ground. Figured I'd look at it when I got to the shop, so I merge into traffic giving it a little gas expecting the TC to kick in, and it doesn't I counter steer and let off and the car dies, stuck in the left turn lane all it will do is fire, but won't stay running, finally let it sit for a minute and it starts up, but the gauges go nuts, reduced power, all needles peg, service tire sensor, everything that can goes off but it's running, shut it off and start back up and everything goes away except a hard service TC notification.
I'm assuming something to do with that wire, anything I should look out for before I rip into this thing?
Old Nov 16, 2017 | 01:35 PM
MBVette's Avatar
MBVette
St. Jude Donor '05-'06-'07-'08-'09-'10
Your issues sound like an alternator problem. Not sure what the wire is though
Old Nov 16, 2017 | 01:49 PM
Shaolin Crane
I noticed the door panel switch went out, wiggled it and everything went away. Guess I'm pulling that thing apart.
there's similar thread with the same issue, will report back after this weekend.
Old Nov 16, 2017 | 02:00 PM
Smoken1's Avatar
Smoken1
Have you pulled the codes?
Old Nov 16, 2017 | 02:26 PM
jd911's Avatar
jd911
Hrmm, not sure it always applies to automotive, but "green is ground, the whole world round".
Jim
Old Nov 16, 2017 | 03:19 PM
dbgoodwin's Avatar
dbgoodwin
door panel switch? I'm curious, do you have a link to that other thread?
Old Nov 16, 2017 | 03:23 PM
Shaolin Crane
I did a little while ago, there's 22 of them which points to a harness problem somewhere.
Old Nov 16, 2017 | 03:24 PM
Shaolin Crane
Jim
Here too, the wire turns out is oart of my HID harness and the balladt unglued itself and that's what it belongs to, so unrelated but coincidental.
Old Nov 16, 2017 | 07:02 PM
Moved to C5 Tech.
To Odd problem with FRC this morning
