02 vert
Old Nov 17, 2017 | 11:08 PM
Bigstew02's Avatar
Bigstew02
Default 02 vert
I noticed black spots on my garage floor at the back area of my Exhaust . I have Borla Touring with 4 tips . I noticed it is wet with water kind of like wet black soot
What is my next step to see if it is engine problems or burning to rich . Funny thing is I check my oil and is at full no signs of excessive oil usage. I revved up the engine and let my Brother check to see if any smoke was coming out . Nothing of any color . Engine does not hesitate or have signs of needing Spark plugs . Engine runs good
. No codes, What diagnostics or What should I get checked ?
Old Nov 21, 2017 | 07:43 AM
ZigZag's Avatar
ZigZag
I'd check nothing, sounds like condensation to me, mine does the same thing. Inside of my pipes are black from soot it's common.
Old Nov 21, 2017 | 06:21 PM
bc6152's Avatar
bc6152
Same here with my '98 vert. Nothing to worry about IMO...
Old Nov 22, 2017 | 10:51 AM
Velocity_Vette's Avatar
Velocity_Vette
I third this.
Water molecules are a byproduct of fuel combustion. It and any residual condensation are pushed through the exhaust and expelled through the tail pipes. It wouldn't be uncommon on a car of the C5's age simply because... well... it's an old car with a build up of soot and byproduct.
At worst it's annoying.
Old Nov 22, 2017 | 07:03 PM
SG Lou's Avatar
SG Lou
with what all of the above said...
Don't worry about it
Old Nov 23, 2017 | 01:07 AM
Rob 02's Avatar
Rob 02
Old Nov 23, 2017 | 09:04 AM
I too do not think this is anything to be concerned about.
Old Nov 28, 2017 | 08:50 PM
Bigstew02's Avatar
Bigstew02
Thanks for that info .
Old Nov 28, 2017 | 11:57 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
have the temps dropped there? cooler air causes more condensation and then you have the droplets mixing with exhaust soot.
when its hot there is a lot less condensation
Old Nov 30, 2017 | 12:24 PM
Bigstew02's Avatar
Bigstew02
Yes they have dropped .
Old Dec 2, 2017 | 10:28 AM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Normal. Nothing to worry about.
To 02 vert
