Which X-Pipe?
Old Oct 9, 2002 | 09:01 PM
mcd_57's Avatar
mcd_57
Default Which X-Pipe?
I have a '99 hardtop with Borla XR-1. Borla promises the sound of a '67 427 with sidepipes......yeah right. Nothing sounds that good. The system is not near loud enough. I want my car to be NASTY LOUD! Any suggestions? Also, I want to know which X-pipe will be the best for me to install (Bassina, Breathless, etc.). I want to get rid of the cats. Does anyone have this setup? How will this sound and about how much can I expect to pay? Where should I buy from? Thanks for any advice.
Travis :chevy
Old Oct 10, 2002 | 01:34 AM
gary brown's Avatar
gary brown
From: Los Angeles Founder, West Coast Corvette Challenge
Default Re: Which X-Pipe? (mcd_57)
I got my x-pipe from West Coast Corvettes. I think that they were about $ 275.00 or so. Ask for Todd.
Good thing about the Bassani's is that they elminated that nasty little popping sound that you sometimes get when decelerating.
Let us know how it works out.
[Modified by gary brown, 12:34 AM 10/10/2002]
Old Oct 10, 2002 | 01:51 AM
rocketcoffeevette's Avatar
rocketcoffeevette
drop the cats and call shawn at lapd, tell him you want the magna-flow, you will like it. it did wonders for me! :yesnod:
Old Oct 10, 2002 | 01:53 AM
robiferretti's Avatar
robiferretti
Default Re: Which X-Pipe? (rocketcoffeevette)
Magnaflo is definately the best...shawn at LAPD go for it, ask for the special price :smash:
Old Oct 10, 2002 | 02:06 AM
mcd_57's Avatar
mcd_57
Default Re: Which X-Pipe? (robiferretti)
What kind of sound difference are we talking about between Bassani and Magnaflow? I want the LOUDEST damn thing I can get! Price on Magnaflow? Thanks.
Travis :chevy
Old Oct 10, 2002 | 02:07 AM
mcd_57's Avatar
mcd_57
Default Re: Which X-Pipe? (gary brown)
How loud are we talkin? What about installation...bolt-on or weld? Thanks.
Travis :chevy
Old Oct 10, 2002 | 02:37 AM
Face's Avatar
Face
MTI sells the Dr. Gas offroad X-pipe, it's the best one out there. Stay away from Breathless, I had one of thier offroad X-pipes and it was complete garbage. Bad bends, bad welds, it needed a good amount of work to fit.
Old Oct 10, 2002 | 02:40 AM
kumar75150's Avatar
kumar75150
Default Re: Which X-Pipe? (Face)
another vote for Magnaflow
Old Oct 10, 2002 | 02:41 AM
Face's Avatar
Face
Hey guys, read between the lines.. :p:
Old Oct 10, 2002 | 02:54 AM
evil-1's Avatar
evil-1
Corsa X-pipe smooths the sound out nicely as well...... :yesnod:
Old Oct 10, 2002 | 03:02 AM
mcd_57's Avatar
mcd_57
Default Re: Which X-Pipe? (kumar75150)
kumar, how does the magnaflow sound? Thanks.
Travis :chevy
Old Oct 10, 2002 | 02:43 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
mcd_57,
Go with the Magnaflow x-pipe and you will be very happy with it.
We always keep them in stock!
Hope this helps.
Shawn
Old Oct 10, 2002 | 02:50 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Which X-Pipe? (evil-1)
For the On-Raod pipe, with CATS kept...they all do the same thing.:) They reduce pop and gurgle on decel, smooth the idle, tame the WOT response a tad and give you a few ponies and ft lbs of tq.
We offer one at $105 and at $269...aluminized metal versus stainless steel.
The Corsa product is the nicest, but, again, they all do the same thing being that they are an ON-raod x-pipe. Some require welding, some are bolt and clamp style.:)
RG
Corsa SS pipe:
CORSA's Ultimate C5 Crossover Pipe™ design provides improved, balanced side-to-side exhaust flow for increased power and eliminates the exhaust "idle burble" and popping on deceleration in most fifth generation Corvettes. CORSA's X-style Crossover Pipe™ improves exhaust flow, at the same time smoothing out the LS1 engine pulses for better throttle response and a cleaner sound. The perfect complement to CORSA's Pace Car Edition muffler system!
CORSA Performance, makers of the World's best-selling C5 Corvette exhaust system featuring it's patented *Power-Pulse RSC™ technology, has focused its attention on developing the ultimate C5 Crossover Pipe. This design, based on sound engineering principles, provides improved, balanced side-to-side exhaust flow for increased power and eliminates the exhaust "idle burble" and popping on deceleration in most fifth generation Corvettes. CORSA's X-style Crossover Pipe improves exhaust flow, at the same time smoothing out the LS1 engine pulses for better throttle response and a cleaner sound.
CORSA's full-length, 2 1/2-inch X-style Crossover Pipes, are made of 16 gauge 304 stainless steel with mandrel bends are designed to bolt on after the catalytic converter and mount to the muffler over-the-axle pipe flange. Each CORSA Crossover Pipe comes complete with installation instructions and all necessary hardware and gaskets. No welding required, just basic hand tools. (a chain-style pipe cutter is recommended for ease of installation). Made in the USA, CORSA's Crossover Pipes are "guaranteed for as long as you own your C5."
Exit 28 Weld-in Unit:
For an off road x-pipe set up with no cats...prepare to wake the dead.:)
[Modified by RG in Dallas, 12:57 PM 10/10/2002]
Old Oct 10, 2002 | 02:54 PM
Face's Avatar
Face
Default Re: Which X-Pipe? (L.A.P.D.)
mcd_57,
He said he wanted to eliminate the cats, how would he be happy with this x-pipe?
Old Oct 10, 2002 | 03:00 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
Face,
He can remove his cats, weld in straight pipe in place of the cats and then run the Magnaflow x-pipe in the rear.
I wasn't the only one on this thread recommending the Magnaflow x-pipe.
Shawn
Old Oct 10, 2002 | 03:11 PM
Moundir's Avatar
Moundir
Travis :chevy
If you truly want Nasty loud, then just get the Slp Loudmouth instead. It's the cheapest route to take. You can buy one new for $500 or pick up a used one for $300. I have this exaust, and I picked up the xpipe not to make it louder but to quiet it down. It is insane sounding. It is classic muscle car, especially with a heads/cam setup. With it you can keep your cats, which will save you more $$ and labor as well and you wont need an xpipe as well believe me :crazy:
robiferretti
Face,
Shawn
And i wont be the only one seconding the reccomendation :yesnod:
I got a friend ;) that has gutted his cats, has TPIS long tubes, the magnaflo x-pipe and the corsa indies, sounds pretty bad butt :cool:
PS: gutting the cats is illegal and not condoned by my post :D :seeya
Old Oct 10, 2002 | 03:13 PM
Moundir's Avatar
Moundir
Travis :chevy
If you truly want Nasty loud, then just get the Slp Loudmouth instead. It's the cheapest route to take. You can buy one new for $500 or pick up a used one for $300. I have this exaust, and I picked up the xpipe not to make it louder but to quiet it down. It is insane sounding. It is classic muscle car, especially with a heads/cam setup. With it you can keep your cats, which will save you more $$ and labor as well and you wont need an xpipe believe me :crazy:
Old Oct 10, 2002 | 04:47 PM
Torched Z's Avatar
Torched Z
Default Re: Which X-Pipe? (Moundir)
The only place he can put an X-pipe in is where his cats are now. The Borla XR-1 has the center resonator so I don't think he can use the Magnaflow or Bassani. He'd have to go with one of the small weld in types that RG sells at eXit-28. I just bought a Corsa Ti Race exhaust from RG and that's the X-pipe I'm planning on buying to replace my cats. :cheers:
[Modified by C5_Man, 2:49 PM 10/10/2002]
To Which X-Pipe?
