18" Tire Size
Old Nov 29, 2017 | 04:50 PM
An UrgeTo Dance's Avatar
An UrgeTo Dance
Cruising
Default 18" Tire Size
I recently bought a 2001 but the owner before me had changed out the stock wheels to an 18" all around set up. The wheels aren't bad so I was wondering what size tires I would need in order to keep the staggered setup for the traction control. Right now the wheels have 275/40r18's on them.
Old Nov 29, 2017 | 05:13 PM
zone-7's Avatar
zone-7
If you were to keep the 275's as your fronts
275 / 40 - 18 = 26.7 dia.
This would work to keep TC happy on the rear
295 /40 - 18 = 27.3 dia.
Old Nov 29, 2017 | 05:53 PM
An UrgeTo Dance
Cruising
I don't see many options in that size. Do you think keeping the 275's as rear and going smaller would work? I have no clue how tire sizing works to do the math myself.
Old Nov 29, 2017 | 06:23 PM
zone-7's Avatar
zone-7
I'm considering & shopping Hankook RS 4s
If you were to keep the 275s as the rear
255/35-18 = 25.0 dia. would work
265/35-18 = 25.3 dia. would also work
Old Nov 30, 2017 | 11:42 AM
REKCUF's Avatar
REKCUF
2016 C5 of Year Finalist
275/35/18 front
275/40/18 rear
Old Nov 30, 2017 | 12:22 PM
zone-7's Avatar
zone-7
275/35/18 = 25.6 dia.
Old Nov 30, 2017 | 11:28 PM
striper's Avatar
striper
In my research when I went to 18" wheels front and rear, I went with 265/35-18 fronts and 295/35-18 rears. Correct diameters and worked perfectly, never any traction control problems. I used 10" wide wheels in the front and 11" wide in the rear.
Old Dec 1, 2017 | 01:06 PM
REKCUF's Avatar
REKCUF
Yes & 275/40/18 is 26.6
Old Dec 1, 2017 | 01:18 PM
Racer_X1969's Avatar
Racer_X1969
305-35-18 Nitto Nt555R on Wagon Wheels
Old Dec 2, 2017 | 11:41 AM
ChrisLSx's Avatar
ChrisLSx
I'm running 295/35/18 on C5 18x9.5 on all 4 corners. I drive mine daily and traction control doesn't care.
Old Dec 2, 2017 | 11:46 AM
slow_pokeC5's Avatar
slow_pokeC5
I'm with 2001CamaroGuy... 18x10.5 on mine all 4 corners, 295/35/18 All 4 corners. Traction Control and Acrive Handling don't give me any issues.
Old Dec 5, 2017 | 08:39 AM
LoneStarLizzard's Avatar
LoneStarLizzard
Look at these two links for discussion:
Here's a link to calculator that former C5 owner (and tech contributor) Toque used: http://www.rimsntires.com/specspro.jsp
And here's a link to Toque's discussion of wheel/tire fitment issues: http://www.toquez06.com/wheels.html
The Lizzard
Old Dec 5, 2017 | 12:38 PM
ChrisLSx's Avatar
ChrisLSx
Did you have to trim your front brake ducts? My front tires just slightly rub the front ducts at full lock.
Old Dec 5, 2017 | 07:55 PM
FASTFATBOY's Avatar
FASTFATBOY
18x9.5 front with a 275/35/18 and a 18x10.5 with a 295/35/18
To 18" Tire Size
