Climate control screen not lit
Thanks,
Tad
Thanks,
Tad
The dim dark display is cracked solder joints in the display and easily repaired rather than replaced. Here is one of the numerous posts on the problem.
https://www.corvetteforum.com/forums...splay-fix.html
When air comes out all vents it is a vacuum supply issue. Cheap to fix but takes a little work to find the leak. Numerous post on this also.
https://www.corvetteforum.com/forums...with-pics.html
Resolder the resistors and find that vacuum leak for the HVAC System vacuum supply!
Those Nylon lines crack easiy and HATE battery acid.
C
