No Fuel Pressure
I am Almost positive there is enough fuel in that tank. When I rook The fuel pump out I must Have lost close to 5-6 gallons. I then Replaced that with another 5 gallon when I finished the install
Two tanks and two sensors, one in each tank. PCM which monitors the sensors has an algorithm that calculates a value to be displayed and sends that information to the IPC via the serial data buss to be displayed on the gauge...............
Easy to just add 5 gallons to the tank (it will all go into the drivers side tank until that fills up) and will give the pump something to work with.......
Unless an external regulator was added to your 99 the fuel filter provides the fuel pressure regulation on the 99 - mid model year 2003. While the regulation function of the filter might have gone bad I'm thinking NOT.. 97 and 98 did have an external regulator under the hood but not on 99 - mid model year 2003.
Suggestion. Don't look for the exotic causes until the simple ones have been exhausted. JMHO
(1) Fuel Feed Pipe
(2) Fuel Feed Rear Pipe Check Valve
(3) Fuel Feed Rear Crossover Pipe (left tank to jet pump)
(4) Fuel Sender Fuel Feed Pipe (jet pump to left tank)
(5) Fuel Feed Rear Pipe (with check valve)
(6) Fuel Return Rear Pipe
(7) Fuel Sender Fuel Feed Pipe (jet pump to left tank)
(8) Fuel Filter/Fuel Pressure Regulator
Visually and physically inspect the following items:
Did you find a problem in any of these areas?
• The fuel filter/fuel pressure regulator (8) for obstructions
• The fuel feed pipe (1) for a restriction
• The fuel pump strainer for obstruction
Cheers,
Goose
(1) Fuel Feed Pipe
Cheers,
Goose
When you stated you replaced the pump, can you clarify?
Did you replace the fuel pump module assembly which contains the pump, level sensor, pipes and wiring?
OR
Did you just replace the pump in the fuel module assembly?
What brand name parts did you use, AC Delco? Other?
Let us know, I will post up detailed trouble-shooting procedures this evening.
Goose
OR
Goose
OK, let’s get you back on the road!
Way forward>
If you do not have a fuel pressure gauge, go to your “local HF tool store” and purchase the fuel pressure gage kit.
Which can quickly test the fuel pump pressure on most injector systems with this fuel injection pump tester. The tester's gauge reads 0-100 PSI, 0 to 7 bar. The fuel injection pump tester comes with flex hoses, fittings and instructions for quick reference.
Troubleshooting Steps;
Fuel System Leak-Down Check
Step 1) connect fuel pressure tester to the injector rail, cycle ignition key from “OFF to RUN” 1 time and verify you “hear” the fuel pump run for approx. 2 seconds. The fuel pump will only run for 2 seconds to pressurize fuel rail which is normal.
Next> verify you have NO fuel leaks at the fuel rail to pressure gauge connection. If you have any leaks correct immediately as is most important NOT to have any leaks for this test.
Next> Cycle ignition key from “OFF to RUN” listen for the fuel pump run for approx. 2 seconds. Do this ignition key cycling 5 times to build fuel pressure in the fuel rail.
Action> Record fuel pressure indicated on the pressure gauge and post your finding.?
Action> with pressure gauge still connected to the fuel rail and indicating pressure, wait 5 minutes and record fuel pressure on gauge and post up your findings.? This test is establishing fuel pressure “bleed down” rate of the system.
LPE provides great PDF instructions with photos for replacing the fuel pump at the following link. https://www.lingenfelter.com/product...l#.WilFfjOWyV0
Question> Did you use LPE PDF instructions to replace the pump?
Question> During the pump replacement did you replace the white convoluted plastic fuel line connected from the fuel pump to the top of the fuel module. This line is 375 MM and if original to the car, it can suffer from aging/fatigue issues and can be damaged/ruptured during fuel pump replacement.
Fuel Pump Pressure output test
To determine that the fuel pump is providing pressure and the white convoluted plastic fuel line connected from the fuel pump to the top of the fuel module is not damaged or ruptured, you will need to connect the fuel pressure gauge to the fuel pump module pressure OUT line.
Step 1) there are 3 pipes exiting the left fuel pump module, identify the main fuel pump pressure OUT line and disconnect line from fuel pump module.
Using a small piece of rubber hose and hose clamp, attach hose and clamp to the pump pressure OUT line. WARNING be careful not to damage to pipe on the fuel pump module while attaching this hose and clamp.
Next> Connect your fuel pressure gauge to this hose and secure hose with clamp.
Now that your fuel pressure gauge is plumed directly on the fuel pump, we will now understand what the pump is exactly putting out in way of fuel pressure.
Next> cycle ignition key from “OFF to RUN” 1 time and verify you “hear” the fuel pump run for approx. 2 seconds. verify you have NO fuel leaks!!!!!
If you have any leaks correct immediately as is most important NOT to have any fuel leaks for this test.
Action> Record fuel pressure indicated on the gauge while the pump is running during the 2 second run burst (you may need an additional person to view the pressure gauge while the ignition key is cycled from “OFF to RUN” during this test). , post your findings.?
Post up you findings so we can get you back on the road!
Cheers,
Goose
Way forward>
Cheers,
Goose
Thank you for your time!
UPDATE:
I got the car running... finally. I decided To do a compression check and found after removing the plugs they were beyond fouled. Lest then 2 hours idle time on them but I’m assuming it’s from burning off all the excess break in and assembly lune I installed During the build process.
Only problem now is after finally being able to take the car out for its first 1/2 mike test run there was a lot of hesitation under a load. Almost like the car was trying to sputter out. Smells like it’s running rich as well. I know It needs a proper tuning and I was Hoping to break it in at least 500 miles first but there is no way I could Drive this car as it is now. Any thoughts on how I can Get this car to somewhat drive right till I dyno tune it?
Recap: sputters, loss of power, hesitation under throttle 1-3 gears, almost dying out, 4th gear through 6th still hesitation but drivable. 383 stroker, sns stage 3 cam from tick performance, billet transmission rated for 1000hp, 4.10 gears in the rear end.
thank you all for you help,
Kyle
Get that car to the tuner.. The bigger injectors are flooding out your new engine..
You may even be beyond the point that the rings will ever seal.
You've washed the new cylinder hone
Trailer it to the tuner... Get it initially tuned so you don't do more damage.
Then get some break in miles on it.. Then back to the tuner with new plugs - again.
Also,... Change your oil and filter NOW.. It'll be full of fuel.
