Cross Threaded Advice... exhaust bolt
Old Dec 7, 2017 | 01:51 PM
Joshboody's Avatar
Joshboody
Default Cross Threaded Advice... exhaust bolt
Last time I removed manifolds, pretty sure I cross threaded first bolt near #2 cyl. No leak and seems solid... IF I don't remove again.
Just changed cam and of course considering exhaust options. Want to replace heads eventually, but considering exhaust beforehand.
If needed, easy to tap and fix with head on the car?
I'm thinking prob should NOT touch it until ready with new heads.
Old Dec 7, 2017 | 02:06 PM
nsogiba's Avatar
nsogiba
It may not be as bad as you think. If you do decide to remove the bolt, you could always run the same size tap (M8x1.25, I think) into the hole to clean up any burrs. Worst case you'd have to drill and retap/helicoil/timesert/whatever (if you can fit in that area). A right handed drill might help.
Old Dec 7, 2017 | 02:31 PM
Smoken1's Avatar
Smoken1
This should work
Old Dec 7, 2017 | 03:18 PM
Joshboody's Avatar
Joshboody
Thanks! Prob no biggy... I just don't have any thread fixing experience and didn't want to make it worse.
Old Dec 7, 2017 | 05:27 PM
vettenuts's Avatar
vettenuts
Went into the local used tool place this past weekend. He had a 8X1.25mm Timesert kit there for $50. Looked like someone bought it, did one hole, then sold it to him.
Old Dec 7, 2017 | 05:47 PM
Rob 02's Avatar
Rob 02
These E-Z Lok are more fool proof than Helicoil.
Amazon Amazon
If you have a drill index and some metric taps you can install them or just get one drill bit and a tap.
Old Dec 10, 2017 | 07:36 AM
Awkwardcrane's Avatar
Awkwardcrane
I would get a thread chaser instead of a tap. A tap will cut through the buggered threads where a chaser will push the metal back where it belongs.
To Cross Threaded Advice... exhaust bolt
