Issue with my headlights
Old Dec 15, 2017 | 03:40 PM
2000CorvetteFRC's Avatar
2000CorvetteFRC
Default Issue with my headlights
On my 2000 Corvette FRC ive been having issues where the headlights dont pop up unless i open the hood and manually turn the ***** on the headlight motor a little, turn the lights off and back on then they will come up. I do not hear any grinding or anything like that.
The picture below is the **** i turn:
Old Dec 15, 2017 | 04:53 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
check your stops...you see one there in the picture (yellow thing) there are several others, if they are missing or worn the light travels down too far and then has a hard time popping up. If the stop is worn you can try flipping it over, if it is missing you need to source some new ones
Old Dec 16, 2017 | 09:19 AM
GCG's Avatar
GCG
Have you checked the rubber bump stops? You might need to replace them.
Also, there is a TSB, that calls for shimming the driver's side motor.
There are 4 rubber bump stops per headlight assembly: 2 for "Close" and 2 for "Open". Check the following pictures to see where they are located.
CLOSE
OPEN
Old Dec 20, 2017 | 04:09 PM
2000CorvetteFRC
Thank you!
So i tried this. i turned all of them over and still having the same issue. It is usually the passenger side headlight that i have been having more issues with. I do have HIDs on the car and instead of the resistor i installed the relay kit.
I started having issues with the right headlight after installing the supercharger and i wouldn't think that would have any effect on it at all but i thought i would let you all know this info.
Old Dec 20, 2017 | 04:54 PM
2000CorvetteFRC
i did flip them all over but i am going to order a new set of 8 and see if that will help. tired of my lights not working. its making me want to drive the cadi a lot more then the vette and thats not good lol
To Issue with my headlights
