cam 2
Old Dec 17, 2017 | 06:05 PM
Richard Mccarthy's Avatar
Richard Mccarthy
1st Gear
Default cam 2
putting in cam 2 will it make it faster 2000 with bola exhaust, cold air,
Old Dec 17, 2017 | 08:11 PM
JR-01's Avatar
JR-01
Do you mean the oil?
Old Dec 17, 2017 | 08:22 PM
dbgoodwin's Avatar
dbgoodwin
At this point I have no clue what's happening but I'm glad the OP has nice cold air from his AC.
Old Dec 17, 2017 | 08:37 PM
Efx's Avatar
Efx
Old Dec 17, 2017 | 08:50 PM
Rob 02's Avatar
Rob 02
Dual overhead cams on a LS1?
Oil won't make it faster.
Old Dec 17, 2017 | 09:09 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
I think the OP is saying the car has CAI and Borla, and asking if putting a different cam will make the car faster.
Even with that possible clarification, OP, we need more details. What are the cam specs? Any other work being done? If the car is an A4 are you adding changing to a torque converter that takes advantage of the cam? How are you tuning the car for the new cam? Etc.
It's quite possible you could add a cam and pick up some speed, but it's also possible you could put a cam in and not support it with additional work and the car would fall on its face.
I think everyone here is pleased to try and answer your question, but more details are needed.
Old Dec 17, 2017 | 10:45 PM
With the right choice in a cam and associated other changes, you'll gain HP/torque and yes, it should be faster. But for better advice, you really need to provide a lot more information than what your original post does.
Meanwhile, I'm going to move this to the C5 Tech section where the members can give you some good advice depending on what your goals are.
To cam 2
