Which gears?
Old Oct 10, 2002 | 07:18 PM
cmeb4dk's Avatar
cmeb4dk
Default Which gears?
Well I am doing everything else what the hay. 6 speed, H/C, projected HP 400-420 Tr224/112 with decent TQ on bottom. If I go with 4.10s will I have to feather the throtle to avoid massive wheel spin? Which unit will have the best durablity? I understand Getrag makes the 3.73s dont they make our stock 3.42s? Which gear will is the whiniest?
Greg
Old Oct 10, 2002 | 07:25 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Which gears? (cmeb4dk)
I have had 3.42's and now have the 3.73's. Neither of these gear sets make any noise. True the 3.42's are made by Getrag but the 3.73's are shot peened for better quality.
Its a hard choice to make... when in doubt, just add more HP!! :eek:
vetterdstr :cheers:
Old Oct 10, 2002 | 07:57 PM
KingTut's Avatar
KingTut
Default Re: Which gears? (vetterdstr)
The beauty of a mn6 is you select the tranny gear. There for why limit your choices by selecting too low a rear gear. With the 4.10's if you think they are reving too high just shift up to the next gear, and when you want more pop down shift.
No amount of shifting can make 3.73's be 4.10's.
Old Oct 10, 2002 | 08:10 PM
cmeb4dk's Avatar
cmeb4dk
Who makes th e3.73 and 410s?
Old Oct 10, 2002 | 08:58 PM
vetterdstr's Avatar
vetterdstr
When I went to the 3.73's I purchased the entire carrier. I bought it through a GP from TByrne. At that time the gears were not available by themselves like they are now. What I am actually thinking of doing is to install a M12 and Z06 3.42's. :)
vetterdstr :cheers:
Old Oct 10, 2002 | 09:13 PM
los7883's Avatar
los7883
vetterdstr :cheers:
I would like to know which ones are better too...when you see the prices on our vendors sites are these prices for the entire unit/carrier??? A guy I know said that he just had the inside worked on...if that is the case would I be able to swap out the guts in my 3.15's for 3.42 or 3.73's? How much would this cost for parts and labor to install it?
Old Oct 11, 2002 | 12:07 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Default Re: Which gears? (los7883)
By the time you buy gears, bearings etc and the labor to install it all in the case... it's just better to buy one already built. I've had a couple built and it cost as much as buying a built unit. I have 4.10 s in stock and can get you other ratios.
Old Oct 11, 2002 | 12:16 AM
Wide Open Throttle's Avatar
Wide Open Throttle
Default Re: Which gears? (Andy@AandACorvette)
4.10's all the way.
Old Oct 11, 2002 | 12:49 AM
MelloYellow's Avatar
MelloYellow
Default Re: Which gears? (Wide Open Throttle)
4.10's if you plan on having less than 450rwhp.
3.90's if you plan on more than 450rwhp.
Old Oct 11, 2002 | 10:02 AM
cmeb4dk's Avatar
cmeb4dk
Default Re: Which gears? (MelloYellow)
No doubt the 4.10 will be the best for the track. My concern second to performance is driving at 75 to 78 mph. I would like to be at 1800 or so rpms. Driving 200 miles ar 2100 rpms might take cockpit noise a bit overbearing. For this reason I am leaning towark 3.90 or even 3.73s.
What would my mph be at 80 mph with these gear choices? Seems like it is 1650 with stock 3.42s.
Thanks,
Greg
This became evident to me after doing my homework last night. Thanks all the responses and thanks for the info yesterday Andy!
Greg
Old Oct 11, 2002 | 10:32 AM
6Speeder's Avatar
6Speeder
Well, I have a simular motor, just a LITTLE milder cam, but respectable power, and traction is a problem in first and second. With 3.73:1 gears and 335/35-17 fairly sticky tires I have to baby it off the line. Then, after I'm hooked and running good at WOT, at about 4800-5000 rpm it breaks the tires loose again!! I don't dare powershift to second, it just fishtails halfway through. I can't imagine how you could hookup on street tires with a 4.10:1 gearset :eek: If yours turns out anything like mine, the 3.73:1 gears are a better choice. Besides, you can get them NEW, with shotpeened gears like on the Z06, so they're plenty strong. :chevy
Old Oct 11, 2002 | 01:07 PM
cmeb4dk's Avatar
cmeb4dk
Default Re: Which gears? (6Speeder)
6 Speeder,
Fish tailing down the track was my concern. I am used to shifteing just short of power shifting, sounds like i am going to have to modify my technique and feather into it through 3rd. What rpm are you at in 6th at 75 to 80 mph?
Thanks for the speedy response
Greg
Old Oct 11, 2002 | 07:53 PM
6Speeder's Avatar
6Speeder
Well, my rear tires are a little shorter in diameter than stock (26.3 Vs. 26.7) but I am turning about 1900 at 80 in 6th. It is a very usable gear at those speeds :D
Old Oct 12, 2002 | 10:46 AM
cmeb4dk's Avatar
cmeb4dk
Well I have decided to wait on the gears. I want to wait to do them till I get to go for a spin in cars with different gearing. Also I want to see my dyno gragh and run it at the track with 3.42s so that I can get some idea whether 4.10s would have me shifting into fifth at the traps.
Thanks for the input thus far, keep it coming as I am only putting off getting the gears at least until someone comes up with a hardened output shaft for the short side. I figure I can save some on labor having it all done at the same time. On the down side will I need to reprogram with LS1 edit?
Greg :chevy
Old Oct 12, 2002 | 11:29 AM
Phil97SVT's Avatar
Phil97SVT
If you only plan on doing heads and cam I would go with 4.10s. If your future plans might include nitrous then go with 3.90s. As far as drag racing goes 4.10s is the right gear if your sticking to 346 H & C all motor. I found that 346 H & C + nitrous with 4.10s is too much gear for the traps(shifting to 5th). I am running 3.90s and can trap in the low 130s spinning the motor.
Phillip :seeya
Old Oct 13, 2002 | 08:28 PM
cmeb4dk's Avatar
cmeb4dk
Default Re: Which gears? (Phil97SVT)
Phil97,
How did things turn out with the "drive train" issues? Did you ever get that beast to the track?
Greg
Old Oct 13, 2002 | 10:40 PM
Untouchable00's Avatar
Untouchable00
3.42s, very nice... :lol:
To Which gears?
