Aftermarket Heads
Old Oct 10, 2002 | 08:00 PM
Killrwheels's Avatar
Killrwheels
Default Aftermarket Heads
Guys I need your help......my wife has asked for a reasonable X-mas gift idea and I was thinking about upgrading the heads.
I do not want to dive any further into the motor, and already realize that the '02 Intake is same as the Z06. What options do I have.....looking at around 2000.00 maximum and can consider sending mine back (core charge) to reduce price.
Because the car is a daily driver, it needs to be just as docile and cannot be laid up for a week while current heads are being ported/polished. Although I have a weeks vacation during December.
I am only looking for heads or porting ......not cam
Old Oct 10, 2002 | 08:05 PM
vstella's Avatar
vstella
Default Re: Aftermarket Heads (Killrwheels)
Scott...I did ALOT of research before I made my choice to upgrade my heads..There are soooooo many options. I can cut to the chase for you:D
Give me an e-mail or better yet I will give you a ride in my car so that you can feel first hand what the mod will do for your smile:eek:....I'm right here in Heron Bay, Coral Springs.. :yesnod:
[Modified by vstella, 7:05 PM 10/10/2002]
Old Oct 10, 2002 | 08:15 PM
Killrwheels
Default Re: Aftermarket Heads (vstella)
I may take you up on that ride. Give me some hints and prices. I do not want to deal with cams and a car that is laid up. I was honestly thinking of Lingenfelter or CNC Heads as more or less a bolt on ! Not looking for HUGE horsepower but obviously dont want to spend $$$ for nothing either !
Old Oct 10, 2002 | 08:43 PM
vstella's Avatar
vstella
I completely understand your concerns..I've been there..Oh have I been there!
There are soooo many options and you will have to stay on budget or you will get into more than you want to spend..I know!!! :yesnod:
I can only tell you that at the very minimum insatllation alone will be about $800. This is just installation by a professional like Mike Norris..(the best IMO)Now you have Stage 1 or stage 2 or my recommendation the ARE "street eliminator" which are stock heads ported and polished with stock valves. Any way you go your looking at anywhere from $1300- 2800 or more for the heads! Now you have the accessories which will be needed like upgraded springs locks retainers and seals..just to name a few :yesnod: Frankly I think if you can pony up about $2700-3000( including installation) you will get a nice cam with it too and the result will be a 45-60 RWHP gain and a nice smile..The heads alone will net you maybe 15-25 h.p. There are other options as well but this is a good rule of thumb..give me a call or again stop by this weekend and I can give you a ride and some other options.. :D
Old Oct 10, 2002 | 09:10 PM
tito's Avatar
tito
IMHO just heads is a big waste of time. You would be better off the other way around. Put in a cam instead of the heads. Ported heads with bigger valves means you need a bigger cam to compensate for the the flow. If not you will lose velocity.. and your car will run like azz.
You can get a head and cam package that uses a mild cam, lets say a 212-218 duration with 550 lift and it will be just as docile as it is stock.
Just remember.. if the heads are coming off.. the cam is right there..
as a side note.. my car is my daily driver with head-cam blah blah blah blah.. and its very docile. :yesnod:
Old Oct 10, 2002 | 09:25 PM
ddawson's Avatar
ddawson
Default Re: Aftermarket Heads (tito)
Ditto, I drive mine to work everyday.
Old Oct 10, 2002 | 10:17 PM
SteveL2's Avatar
SteveL2
Sorry to jump on your thread or cause you more thought, but I might be in the same boat. So, I'm adding a question -- how do headers fit into all this? It sounds like people are saying pretty big things about long tubes alone, so if a person is going to over time do heads, cam, headers, or just 2 of the 3, what do you folks thinj would be the best order to do them? Thanks. :cheers:
Old Oct 10, 2002 | 10:26 PM
Killrwheels
Default Re: Aftermarket Heads (SteveL2)
I had SLP Headers on my Ram Air T/A and they burned wires all the time. Not to mention the additional noise they created ! While SLP ultimately allowed me to return them and they Jet-Coated for free, I had computer trouble and MAF trouble that Pontiac contributed to the extra heat collecting under the hood during the two years I ran them. And they could never get the Optispark to work .....but thats another story.
I thought some bolt on Lingenfelter Heads 1500-2000 would be small jump of 25-50hp.......but if a cam is necessary, I think I will wait till the warranty ends in 2005 .
Old Oct 10, 2002 | 11:10 PM
Tom Steele's Avatar
Tom Steele
Some thoughts.
First, long tube headers are a good idea. Keep the cats while you have the warranty.
Second, the cam will not void your warranty. I'd do both cam and headers and you should be on track for budget and you'll get a pretty solid improvement in hp...
That'll be two cents please. :)
Old Oct 11, 2002 | 11:29 AM
FreddyG's Avatar
FreddyG
If I had to do one or the other, I'd do a cam. It makes more power than the heads will by themselves. If you can get them both, then that's the way to go.
I'm thinking of just getting a cam and headers now too.
Old Oct 11, 2002 | 11:36 AM
vstella's Avatar
vstella
I wouldn't worry about warranty..with the right service writer ..a cam and headers won't be a problem...The dealer I use has NEVER given me a lick of trouble even with my car being all modded .. :yesnod:
Old Oct 11, 2002 | 11:25 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Yes sir, if you just do one, heads or cam, going with just the cam is a no brainer vs. just heads! :smash:
Nitrovette:D
Old Oct 12, 2002 | 02:35 AM
gary brown's Avatar
gary brown
From: Los Angeles Founder, West Coast Corvette Challenge
Default Re: Aftermarket Heads (Nitrovette)
Absolutely, the best bang for your buck - if you are only going to do one item now - would be the cam. I would recommend a nice tasty MMS 218 cam for your car. This is an excellent introductory cam and will work very nicely with stock heads or Stage 1 heads.
More duration than that, and you really should do heads AND cam at the same time.
As others on this thread have suggested, Yyou might want to consider spending a bit more NOW by doing both heads and cam. It WILL SAVE YOU lots of $$$ later in repetitive labor costs, if you do both together.
Also, you are VERY luck to have vstella in your neck of the woods. As you can see, he and I are modded along very similar lines. He has a WEALTH of knowledge that will aid you in picking the right mods AND help you save money in the process. You could accurately view him as the C5 Yoda of Florida! :yesnod: :lol: :rolleyes: :D
Old Oct 13, 2002 | 06:10 AM
388 SOLid RoLLeR's Avatar
388 SOLid RoLLeR
Default Re: Aftermarket Heads (gary brown)
heads vs cam... hmmmm
LS1 heads flow very well to begin with. Doing a cam would be worthwile as well but some more $$ too.
My reccomendation.... leave the cam.. have the heads done. change the rockers to the crower 1.8 rr's. that will give ya some extra lift.
about needing a cam for ported heads.. that aint true. i vote for heads over the cam.
Old Oct 13, 2002 | 11:08 AM
vstella's Avatar
vstella
..Also, you are VERY luck to have vstella in your neck of the woods. As you can see, he and I are modded along very similar lines. He has a WEALTH of knowledge that will aid you in picking the right mods AND help you save money in the process. You could accurately view him as the C5 Yoda of Florida! :yesnod: :lol: :rolleyes: :D
Yoda...? :rolleyes: ..Hmmmmm...I DO have the force with me now :lol:
Old Oct 14, 2002 | 04:20 PM
QwikSilvr's Avatar
QwikSilvr
If your budget is limited, I would get:
cam 218/218 with .550ish lift
upgraded springs, retainers etc
cold air intake like vortex or other brand
LS6 Intake (if you don't already have it)
LT Headers (can be had for well under $1000)
All of that should fit within your $2000 budget including labor to install.
Only thing is, you will need tuning, which you may be able to fit into your budget if you shop wisely. I think you could pick up between 55 and 70 hp at the wheels.
Old Oct 14, 2002 | 04:33 PM
Bill Reid's Avatar
Bill Reid
While I'll agree that a matched head/cam package is the way to go remember the man's budget. The cam may be "right there"... but you only have to take the steering rack out of the car to get to the harmonic balancer to get to the timing chain cover to get to the cam... and all the sudden the budget just got blown out of the water by being doubled at a minimum... this assuming you pay the labor for having heads/cam installed by a reputable shop. Oh, and don't forget about dyno tuning for optimum hp/tq gains:)
I would save for the whole package :yesnod:
Good Luck :cheers:
[Modified by billreid1@***.net, 1:34 PM 10/14/2002]
To Aftermarket Heads
Old Oct 14, 2002 | 10:51 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Default Re: Aftermarket Heads (billreid1@***.net)
If you're absolutely set on first doing heads then look at GMPP CNC'd LS6 heads for ~$1,970 with no core charge required ( which will offset your initial costs if stock heads are resold), '02 Z06 springs included, and sodium filled valves are also included...the useable flow numbers for a street application are very good.
If your options are still open, I'd first go cam (best bang for the buck), and then headers and a great tune. Just keep in mind a complete plan for future mod compatability. I myself am collecting compatable parts so install and tune will only be done once (I hope).
Old Oct 14, 2002 | 11:03 PM
tds69tx's Avatar
tds69tx
When I win the lottery---I'll duplicate NoMercy :smash: :smash:
Old Oct 14, 2002 | 11:09 PM
tds69tx's Avatar
tds69tx
Wished I was closer to Extreme. Nate quoted me a hell of a deal on LS6 Intake, Stage II Heads, Stage III Cam (don't recall specs), Long Tube Headers, and of course their Dyno Tuning. He said this would put it @ over 400 rwhp and that it would be very streetable! Gotta save that MOD $$$$! :yesnod:
