Key fob replacement?
Old Dec 28, 2017 | 10:05 PM
Kagnus's Avatar
Kagnus
Default Key fob replacement?
2000 C5 MT 70k
What is everyone doing to replace their failing key fobs?
Old Dec 28, 2017 | 10:46 PM
DaDuck's Avatar
DaDuck
My Y2K vert is not a daily driver .....so I just use the key and the door lock switch.
My fobs need to be reprogrammed just about every time I go to use them.
Old Dec 28, 2017 | 11:06 PM
grantv's Avatar
grantv
EBay... where I got mine.
Old Dec 29, 2017 | 06:50 PM
Kagnus's Avatar
Kagnus
Originally Posted by 8VETTE7
Have you read and tried the solution to the early year FOB problems from this thread?
http://forums.corvetteforum.com/c5-t...em-solved.html
I have, except the fob has a chip in the casing and the seal is exposed.
Thank you for watching out for us 8VETTE7!!
Old Dec 30, 2017 | 07:14 AM
jdmvette's Avatar
jdmvette
Night Owl for life
my Y2K *is* a daily driver and I got sick of using the key every day...being unable to open the trunk, manual locking etc. reprogramming every time, same issue as you.
I had bought a new OEM Y2K fob (expensive) several years ago after the originals both died. it lasted a while but now its been about a year since my latest fob started going out. even with reprogramming/relearning/battery replacing...that new fob kept losing sync.
I ended up putting in an aftermarket keyless entry for $40 and now my car works as it should once more. the range on the new system is much much further than the stock range was so I am very pleased.
here's what the new fob looks like
wiring wasn't difficult with the help of some forum members and a c5 diagram.
let me know if you want more details in case you want working fobs again.
Old Dec 30, 2017 | 08:26 AM
99mike's Avatar
99mike
St. Jude Donor '17-'18
Upgraded to the 01-04 TPMS system. Never looked back.
Mike
Old Dec 30, 2017 | 03:35 PM
99mike's Avatar
99mike
Bet it was a bit more than the $40 solution mentioned in post #6!!!!
That is correct sir. I needed new tpms as well, so it was the right choice for me.
Old Dec 31, 2017 | 11:36 AM
DaDuck's Avatar
DaDuck
Mike
I last time I looked at the conversion kit from Gene Kelley, there were some parts on back order. So I bought 4 new Tire sensors and had them installed with new tires about 3 years ago.
When my Tire sensors fail, I will probably buy the 01-04 conversion kit.
Not having a working remote is not a big deal to me.
Dave
Old Dec 31, 2017 | 10:56 PM
Bigbubba78's Avatar
Bigbubba78
Do you have link to keyless entry and wiring diagram ? Did it pop hatch also? Thanks bubba
Old Dec 31, 2017 | 11:34 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Yes sir! Cheaper now than when I bought it too!
Amazon Amazon
It pops hatch and turns on interior lights. It flashes parking lights and honks the horn in use if you connect the lighting and horn leads,.
I'll get you more info shortly.
Old Dec 31, 2017 | 11:54 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Here's a quick video I made showing the basic functions of the unit.
To Key fob replacement?
