Key FOB Training not working.
Old Jan 2, 2018 | 11:50 PM
Cliff99C5hardtop's Avatar
Cliff99C5hardtop
Default Key FOB Training not working.
I have a 99 C5 and I purchased a TPMS upgrade kit from Cultrag Performance which comes with new key fobs and module. I removed the old module, wired up the new module and went into the DIC to do the relearn. I went though the whole process....cleared DIC etc and it goes into FOB LEARNING but will not do anything from there. It will only stay in FOB LEARNING but will not do anything else. Held down lock and unlock but nothing happens. I went through old posts and no one had the answer. I tried everything except disconnecting the battery to reset everything.
Old Jan 3, 2018 | 01:04 PM
Cliff99C5hardtop
Originally Posted by 8VETTE7
Pull and post the codes associated with B0-RFA. Is there a NO COMM next to the B0-RFA?? Are there any UXXXX codes where XXXX are numerics?
BO-RFA NO COMM. No other codes present. Also when I scroll through options is now says PASSIVE UNLOCK - -. It never said that with the old module....my guess is Passive is no longer a function. Would that have something to do with it?
Old Jan 3, 2018 | 08:49 PM
Cliff99C5hardtop
NO COMM is the cause of your not being able to do the FOB training.
The RFA is not able to communicate across the Serial Data Buss.
I would go back and make certain you have the necessary wiring changes for the newer year RFA correctly done. The FOB's and TPMS transmit coded radio signals to the RFA and the RFA converts the radio transmission to a coded electrical signal that is sent over the serial data buss to communicate with the BCM, IPC etc. NO COMM is preventing this communication.
I will double check my wiring tomorrow. I also have not done my wheel sensors yet, would that have anything to do with it?
To Key FOB Training not working.
