Selective Ride Issue
Old Jan 5, 2018 | 04:30 PM
dp03's Avatar
dp03
6th Gear
Default Selective Ride Issue
I have a 2003 with 52,000 miles. The car rides like a buckboard. I've checked codes, had none. Removed left rear tire and checked shock for shipping Stop, none. There is power to the switch, power coming seem weaker. Traction control switch seems fine. Any suggestions?
Old Jan 5, 2018 | 04:34 PM
Moved to C5 Tech.
Old Jan 5, 2018 | 11:29 PM
coia96vette's Avatar
coia96vette
Are you sure there are no shipping blocks there? They would be under the boots with just a yellow strap hanging out of the bottom. Still can't believe after all these years that people are still finding them.
Old Jan 6, 2018 | 08:18 AM
Joe Scafide's Avatar
Joe Scafide
Default blocks
I know i have 2003 and just found blocks last season but look for black tabs from road dirt not yellow anymore
Old Jan 6, 2018 | 07:32 PM
dp03's Avatar
dp03
6th Gear
Checked both rear shocks and no blocks. There is power to the selection switch. The power coming out is weak. Don't know if that' normal. Nothing changes switching from tour to sport. Was wondering if the switch could be bad. Feels like it works find. Smooth roads she rides fine, jars your teeth on a bump. Thanks for all the help.
Old Jan 20, 2018 | 07:14 PM
dp03's Avatar
dp03
6th Gear
Default Found Stuffers
Thanks to everyone for their help. Finally took the front tires off and guess what I found. Yep, front shocks still had the stuffers in them. The backs were removed but not the fronts. Going to take her out now and see how she rides. Thanks Again.
Old Jan 20, 2018 | 10:21 PM
coia96vette
Glad you found the problem and did not cost anything. Those magnetic shocks are very expensive but do work very well.
Old Jan 21, 2018 | 10:14 AM
Awkwardcrane's Avatar
Awkwardcrane
How obvious are they when leaking? I checked mine and there was a film of brake dust on them. I’m thinking that is normal?
I checked them because I too cannot tell a difference when switching.
Old Jan 21, 2018 | 10:53 AM
Awkwardcrane
Ya, checked for the stuffers a couple times. All I have is a very thin film of black somewhat oily dust which I suspect is normal. I don’t see any signs of oil any where else.
Just wonder how obvious the ride change is when switching because I don’t notice anything.
To Selective Ride Issue
