Ned Help: Header Install causing O2 sensor problem
Old Oct 11, 2002 | 08:36 PM
johnnyC5's Avatar
johnnyC5
Default Need Help: Header Install causing O2 sensor problem
Has anyone had any difficulty/problems with their O2 sensors after installing TTS Headers?
Shortly after the install, about 60 miles of driving, CHECK ENGINE light comes on. Take it back to the shop, run a scan, and tells us the O2 sensors are screwed.
The shop that did mine had to extend the wiring to one of the sensors.
The wiring melted, causing the error codes. Replace the O2 sensors and wiring. This was 2 days ago.
Now Check Engine light is coming back on for about 50 miles, then goes off for about 20 miles, now it is back on. This is what happened the first time around, when the error codes were reporting bad O2 sensor readings. I suspect the same thing now. Are the headers melting the wiring?
I'm just wondering if anything else could have gone wrong with the O2 sensors or wiring itself. Never had this problem before installing the headers.
[Modified by johnnyC5, 2:22 AM 10/12/2002]
Old Oct 11, 2002 | 10:02 PM
movinup's Avatar
movinup
Default Re: Ned Help: Header Install causing O2 sensor problem (johnnyC5)
If the wiring is OK then it's possible the headers could be leaking and causing the o2s to fail. Check your codes on the DIC.
