No Communication to BCM
Last edited by Armand Gagnon; Jan 15, 2018 at 08:52 PM. Reason: UPDATE: 105,000 Miles I forgot to mention....
What ever you decide DO NOT just start throwing parts at symptoms!!!! That will get very expensive very fast. You need to identify the cause of the NO COMM first...........
You should follow the advice of 8VETTE7 and post all the codes.
This problem has been extensively documented by Bill Curlee and you can read more here. It is usually caused by bad contacts in a connector within the doors' rubber accordion.
The Serial Data Bus goes through the rubber accordion to the door control module. The female pins of the connector on that wire harness get deformed, causing bad contacts and loss of communication/corruption in the Serial Data Bus affecting all modules linked by it.
You can troubleshoot by opening the Star Connector 2 by the passenger's foot well, which isolates both Door Control Modules along with the Left Seat Control Module, and if communications are restored then you have your culprit.
Check the connectors for deformed pins. If bad pins are found you would need to repair the connector, fixing the female pins so they have a positive grip, or replace it. If you want to replace the connector take a look at this post for some ideas.
If connectors are fine, then the problem should be downstream the connectors up to the door control modules, or in the wiring/connector for the driver's seat up to the seat control module.
The Star Connector 2 is the one that has four wires. To perform this test you have to pop the top shorting strip off the top of that connector.
Let us know how it goes
BCM/PCM RELEARN PROCEDURE
You will need to conduct the PCM/BCM relearn process. This matches their handshake ID's and allows them to talk to each other.
Do this before you worry about VATS issues:
1. Turn on the key for 11 minutes.
2 Turn off the key for 30 seconds.
3. Repeat 1&2 two more times.
4. Turn on the key for 30 seconds.
The car should start and run with the new BCM. Good luck and report back on your progress.
Shirl
SD Racing Enterprises
Aguila, AZ
Coutersy of MrEracer
When you say that the passenger window and door lock still don't work have you verified if that is the case in all these 3 scenarios?:
- Window and lock actioned from the driver's side
- Lock actioned from the key fob
- Window and lock locally actioned from the passenger's side
The first 2 actions involve communication through the Serial Data Bus, while the 3rd action does not.
If they don't work in neither of the 3 mentioned scenarios, you might have problems with the relays as suggested above, but if the problem is only with 1 and 2 while 3 is fine, then it should be either a comm problem with the RDCM or that the RDCM is not processing the commands from the BCM.
The female pins of your passenger's connector don't look good and that might be a problem. They need to have a positive grip. Bill Curlee uses a male pin attached to a short wire to test the grip by inserting and removing it in each female pin.
Compare your connector to Bill's picture. They look very similar (actually, yours looks worse
):Yours
Bill's
If you can't fix those female pins, you would have to replace the connector or, as you mentioned, make direct connections soldering and using heat-shrinking insulation. I posted a link before to give you some ideas if you're going the replace route.
Super explanation and I completely understand. I just ordered it and will have it Thursday. I will do exactly as you instructed. I buttoned up the car tonight and will take it for a short ride tomorrow to see if it goes over 2mph after the BCM programming. I have NO CODES except the right mirror code that I mentioned earlier! I cleaned all four udders and pulled off the AC hose on firewall until I see something come out of it tomorrow. I ran the car for 30 minutes-ish tonight and saw no condensation or dripping coming out of the little plastic pipe coming out of the firewall. Also, no water inside next to or above BCM or on the floor. I just had the AC charged today and the dash vents air temp is 39 degrees. It's about 42 degrees here in Connecticut but I still think that there should be some condensation coming out somewhere. Oh well, maybe tomorrow.
THANKS AGAIN!
You are in good hands regarding the LMC5. 8VETTE7 is the Guru in this subject
